Results 1 to 14 of 14
Thread: New Tires For Ice Fishing
    Mar 2014
    Iowa
    78
    Looking for suggestions on new tires for my 1983 Honda 200a three wheeler
    Right now I have 25x12x9
    I will be using it for ice fishing only ( right now anyway )
    For the Rear :
    I have read about Maxis 4 snow's
    I have read guys suggesting Bear Claws
    For the Front:
    I have seen suggestions about the Kenda Front Max
    For the first ice its slick with little to no snow cover
    Then later it might get some snow and it might be hard packed or driftey.....
    For the Ice fisherman.....whats going to be a good combonation..
    Kenda Max Front
    4 Snows on the back
    Kenda Max Front
    Bear Claws on back
    Should I get a set of Chains ?
    I don't really don't what to put studs in my tires
    If I stick with my rear tires I have and use chains I definitely want to get a new tire for the front so it steers better.
    Is the Kenda Max Front the way to go on front ?
    It would be a different size than I have now
    Looks like it would be a 21x8x9
    Would that be ok to run with my current rear tires ? 25x12x9
    Thanks,
    Mike
    Mar 2013
    Wausau, WI
    147
    Definatly get the 4 snows for the back, the grip is insane in the snow and pretty good on ice as well
    I disagree wholeheartedly. 4snows are a snow tire, not an ice tire. They're just as bad as any other unstudded tire on the ice. The only way you're truly going to be able to move on the ice is with studs or possibly chains. I've never personally run chains so I can't speak too much about that. I have run studs though and I have run 4snows unstudded on ice. You wouldn't be impressed.
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Stay away from Kenda for the ice. What make they so great is that they use a hard compound rubber for high wear resistance. On the ice you want so rubber. 4-snow are soft compound and you can lower the air pressure as low as you want.
    I think chain is a very good idea. I want to try it this winter.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Cold Lake, Alberta, Canada
    3,014
    I'd say stick with rubber only or rubber with studs. I have OHTSU Pro-Vector H-Trac II's on my Camo US90. They work good in most conditions; kind of like the 4-snows. Chains can cause a LOT of damage in a very short period of time. You only need to break one cross link and your nice plastic is a goner. IF you're going to run chains, deflate your tires, install them tight and air up. Then drive slooooooow!
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Maine
    463
    Save money with the tires you have on it now and put a bunch of screws in them. Front and back. They look like they have enough meat on the treads as long as they clear the fenders ok.....Than you can get some nice tires in the spring..Thats what im doing on my sx's this winter...It will get more traction than bumpy clanky chains and those snow tires wont do anything on ice....MFG Supply online you can get a great deal on ice screws also...
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
    Mar 2014
    Iowa
    78
    Thanks for the suggestions,
    So what kind of screws or studs would be the best to use. There are alot of them out there.
    Kold Kutters
    Woodys Carbide twist screws
    Thanks
    Apr 2002
    s.w. michigan
    6,498
    I run chains on a couple of trikes when I was into ice fishing with great success. Economical + don't dedicate a set of tires for one specific use.
    I found that by using good quality rubber bungee stretch cords on both sides of the tire to keep the chains taunt works the BEST. Don't rely on the tire pressure only to hold the chains in place. I gurentee the chains will work themselves off the tires and flop around causing unneeded damage
    The chains I used was old car/truck tire chains cut down to fit rear ATC tires.
    john
    I love Kold Kutters. Don't waste your time with regular screws not intended for use as studs. They will wear out in no time!
    Jan 2011
    Brazil, Indiana
    2,087
    If you use screws do like the previous owner of a trike I bought did. Use screws that penetrate the tire by 1/2". That way they will have hundreds of leaky holes when you take the screws out. And run them till they are worn down so much you have to take a dremel and cut slots in them for a screw driver.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Haha, nice Greg. Honestly most studs do penetrate the tire. If leakage becomes an issue tire slime will solve that. It's worked very well for me.
    Cue the slime haters.
    Maine
    463
    Kold Kutter 3/8-inch would be good if your treads are not deep enough. MFG supply has the 1/2 inch which i'll be getting because my tires will be new with deep treads..Plus the price is about only 50 bucks for 1000 ice screws and they look like a good product made in the usa..This will be my first year doing this also for ice fishing season and they should last with minimal wear unless you drive on any pavement or hard dirt roads which I don't...If you go the ice screw route put up some pics...
    MFG Pro gold 1/2 inch
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    KLT 250 Prairie
    MotorCity is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2007
    Detroit
    195
    I like to ice fish as well. Looking forward this year. I got chains for my '85 Big Red. Works great. Picked them up from Cabellas I think they were around 90.00 4 years ago. Letting all teh air out and installing them, then airing up makes it a bit easier.
    Kold Kutters would work great as well.
    Sep 2013
    Saskatchewan, Canada
    661
    Can't wait for the ice fishing season to arrive - '84 200es is ready to chase some walleyes. That reminds me - need to find my flasher.
