Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 85
Thread: 3 Wheel Golf Cart Build, The "Tri -X- Side", Here Goes Nothing!
  1. #31
    Cold Lake, Alberta, Canada
    3,019
    Quote Originally Posted by jakep53 View Post
    I would look into using a thermostat and fan setup off a trx 300...I think you could make it work?
    I contemplated that jake but the fan isn't available anymore; that's not a show stopper as any 12V fan would work. And when I looked for all the components on servicehonda, I don't see a thermostat. Do you know where it is on the parts list? That's really the only OEM part I'd like to find.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
  2. #32
    I've always wondered where the sensor is on my bike as well so I'll have to take a peek. It's pretty tight in there so I can't make any promises, but I'd really like to know.
    I just read up on it, far too much digging to see it on my bike. There's some good info here- http://www.advrider.com/forums/showthread.php?t=912517
    I attempted to download the pic but for whatever reason it wouldn't work. I then tried to copy the guy's link from Photobucket, but that wouldn't work either. You'll see the pics when you scroll down CoolPool. For the record I do not own a Ulysses, I own a 2009 XB12S Lightning.
    3,019
    Good info fabio, thanks! That does look like a pain to get at. It appears that the cooling fan kits available on 85-87 TRX 250's had a handlebar mounted rider controlled fan. The fans were thermosatically controlled from 88 on for the 300's. Sam and I are going to scour our 1998 300's tonight and see if we can find where they they get their temp signal from. Next problem will be finding the same sensor and seeing if we can make it work. This may turn into a simple switch with a rad fan.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
  5. #35
    Surprise, AZ
    2,428
    Here you go, it can attach to a head bolt..Easy.
    Its adjustable too. You can even use a 2 stage fan set-up from a Ford Taurus (Old hot rod tip they work on almost any project, very universal) $20.00 bucks at a junkyard. Small size too.
    http://www.jegs.com/i/JEGS-Performan...ductId=1557724
    Click on instructions on this page.
  6. #36
    andersonee4's Avatar
    andersonee4 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Ames, Ia
    169
    Would you be willing sell and ship that rear end? To Iowa?
    1985 Honda 250sx. Ground up rebuild. SOLD
    1986 Honda 250es Big Red with custom plow
    Don't waste your time, or time will waste you.
  7. #37
    3,019
    Quote Originally Posted by andersonee4 View Post
    I am but it is going to cost large! It will have to go by pallet due to the weight. You can have it for cheap, cheap, cheap too. PM me if you want me to start getting a quote. If you're patient, I have all intentions of hitting Trikefest and could bring it with me. Maybe we could get fellow members to get it closer to you after that? Probably weighs in around 80-100lbs.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
  8. #38
    Apr 2013
    snyder texas
    456
    you might check boat supply places for cupholder i believe they have them in 3" diameter
    you know whats right therefore you know what is expected
  9. #39
    3,019
    I had her out for over two hours on the lake today. Everything worked as it should for the most part. The front wheel bearings started to squeal at the end of the run. I should of expected as such after 50 years. I installed the tail lights and started fixing up the console. Got quite a few "wtf" stares as I rolled by the fishermen. What.........never seen a golf cart cruise past on the ice at 30mph? Time to start upgrading the front end to a 250R one.
    Attached Thumbnails Attached Thumbnails IMG_1231.JPG   IMG_1232.jpg   IMG_1233.JPG   IMG_1234.jpg
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
  10. #40
    Feb 2014
    Victoria,Australia
    878
    That is awesome nice work!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
  11. #41
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    More likely to carry seal clubs in that than golf clubs.
    The Goal... All I Need Is The Time...
  12. #42
    Mexico
    9,018
    Does it have a beer heater on it?
    It sucks to get old
  13. #43
    Austin, Massachusetts
    1,591
    its awesome, man. followed the build and thats nice work!! really cool and unique. as far as the cup holders, did you ever consider going to a junkyard and poke around? where you're rig is so custom, something might be easily converted and look nice. Get yourself a wood trim, fold down unit like the Yukon Denali rear seat setup. or whatever else. there are thousands of options. just a thought. if you do go the PVC pipe route, get a larger 5 inch pipe and glue in the standard foam koozie. it will provide a more secure fit for the beverage and keep it cool in the summer and un-froze on the ice. Drill a slightly larger hole in the bottom for drainage and reduced vacuum.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
  14. #44
    Surprise, AZ
    2,428
    How about a simple roll bar? just in case...
    Add a couple of LED lights to it.
  15. #45
    Jul 2014
    Lloydminster, Alberta
    503
    Haha don't get him started with LEDs, father hates LEDs
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
