Thread: 85 250sx help with clutch!!
    Oct 2011
    Nashville,tn
    32
    Is there an expert bold enough to call me on my cell phone to assist with adjustments?
    I out new friction and steel clutch plates, new springs, new centrifugal shoes, new one way, but while shifting and holding gear lever up it stays in gear. And it still slipping more than it should... My main concern is how tight or far you want to tighten bolts down over the clutch springs. It was acting like it was engaged full time slightly but never really fully engaged. Call me bc i am away from PDF manual download on computer and working as we speak. Call 706292 3398 please!!! Experts!! S.o.s!!
    Oct 2011
    Nashville,tn
    32
    7062663398 not number in post.
    Jan 2011
    Choctaw, OK
    2,755
    calling.......
    Oct 2011
    Nashville,tn
    32
    So clutch is all put together. Still there are issues with adjustment being difficult to shift. Also i think the return spring on shifter pedal is not correct. I am pulling the left side off to have a look. Do you have any suggestions for clutch adjustment issues? Nothing looked warped or misaligned.
    Mar 2014
    quebec canada
    8
    Hi I have similar problem just changed timing chain and centrifugal clutch bearing ... motor and when in reverse its like new when I put it in first the motor rpm goes up but hardly will move foward ... im thinking it is the 4 clutch springs I tightened them so they are totaly compressed ... in the manual cant seem to find at what tork they have to be or how to tighten can someone help me please
    Pacific NW
    4,255
    No torque specs in the manual?
    Sounds silly but messed me up.......external shifter was bent and dragging on the
    engine case.
    Not real obvious and had me fooled for a few days.
    Unhappy gf till I got it fixed.
