Results 1 to 7 of 7
Thread: pull start help
    Sep 2013
    gardners pa
    27
    pull start help
    I have attempted to reinstall the internal components of a 85 200s pull start a couple times w no success. I bought a kit online that fits the machine and functions while assembled in my hand, once I install the recoil starter onto the motor and pull it a time or two the mechanism comes apart. I have reviewed the manual yet have failed. Any help on this matter would be greatly appreciated.
    Thanks
    Mar 2014
    Iowa
    78
    I took my 200 pull starter apart and cleaned it up and put it all back together with now issues....I had never seen one before let alone rebuild one. One thing I did do was watch " D-Ray's " youtube video on rebuilding a pull starter. Hope you find the problem
    http://www.youtube.com/watch?v=TOGNeuJN9dE
    Apr 2012
    USA
    4,133
    Photos of what it looks like might be of help. Never rebuilt one, but there should be some sort of a bolt that holds the assembly together.
    I just took a quick peek at a 125m pull starter, and it has a huge washer with a nut that holds the assembly in the cover, I would start there as that should stop it from falling apart.
    Jul 2013
    mo
    327
    im willing to bet that the pulley is worn out. the area where the dog ears lay . inspect that area closely. i had one that that had hairline fractures everywhere. also the point where the dog ears are to stop will smash away over time and allow them to fall out. grab a welder and a grinder and add some metal to that point and grind your welds smooth . good luck.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Sep 2013
    gardners pa
    27
    Ok ill post some pics tomorrow to get opinions
    Sep 2013
    gardners pa
    27
    Sorry it took so long to get the pics up. Click image for larger version.
ID:	201983Click image for larger version.
    glendive, montana
    1,822
    here try my video and see if there is something you missed I did see some wear but doesn't look to bad and if it worked before you took it apart then you put something in there wrong.
