Results 1 to 3 of 3
Thread: Honda XL 350
    350Xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Huntington, W.V.
    320
    Honda XL 350
    I have a 1974 Honda XL350 4 stroke and every time I get it out it fouls a spark plug it is a really dry carbon type fouling. It isn't running to rich either. I think it could possibly be because the battery is dead and sof the older bikes had to have a fully charged battery top run right. It has a really nice blue spark when a fresh plug is put in,but then it starts either firing white or sparking blue but all over the insulator.I can put a new plug in it and run it for about 20 minutes or so and it runs like a top,but after that it will hardly accelerate and wants to die out. The valves are probably out of adjustment a little bit to,but I don't really think that that would cause it? ANything that you can think of that it could possibly be please let me know.Thanks a lot
    ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
    Rittman, Ohio
    6,276
    Probably 95% of eletcrical problems are caused by the points in models that have them, and while I dont know anything specifically about the model you mentioned, its probably one of those points machines.
    PLJ. is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    253
    Fire.
    Good possibility that it could be the points. That XL is a point ignition machine. Points sets are cheap. Lower that thing down, rake in the front end, glass tail section/tank, 19" wheels, configure some disk brakes off of an old three wheeler, add a Jemco low pipe and you will have a great handling dirttracker. I have a 74 XL myself, but mine is a 250. Well, it says that on the outside!!!! Megacycle kit installed. Those XL350's are hot up here in the north for play iceracing!!!
