Results 1 to 3 of 3
Thread: what tires for my tri-z 250 to replace the originals
    Sep 2014
    Rotterdam area, the netherlands
    41
    I was just wondering what tires or better tire size i could use for my tri-z. Making it road legal but love to take it out to the forrest, is there a good compromise for both terrains? (should fit the original 8'' rim)
    Like for my yamaha grizzly 700 I use the maxis bighorns as they operate quite well in all terrains.
    Thanks for your thoughts!
    Piet
    Edit: original rear tire is 22-10x8
    glendive, montana
    1,822
    actually my friend in my manual it says oem were 22-11-8, I actually recommend staying with that size if you are making it street legal, plus they give you clearance for when you are on the trails. you can go with 20-11-8 but they will slow you down on the road and keep you more into higher rpms on the road.
    JesseA420's Avatar
    JesseA420 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    Nebraska
    147
    you can use any atv tire for the rear, given whatever size rear wheels you have. front you are rather limited though.
