I'll continue on
I need to answer these questions first.
The piston was purchased from the machine shop that bored the cylinder.
The std bore cylinder was bored to 82 mm and the piston was hone fit to the cylinder.
The piston rings supplied with the kit were installed 180* apart from one another starting g with the oil ring.
We installed the cylinder and head at that point we clayed the piston and took measurement to be sure of piston to valve clearance. We also measured coil bind at max lift on every valve. When we reached .425 we stopped measuring.
As the engine was assembled we checked every part for free movement as the next corresponding part was installed.
The motor has tons of compression without the decompression cable hooked up you can barely kick the bike over. All symptoms were prior to the goki install. Cam timing is correct the cylinder received mild port work and blending. New valves seals springs retainers and keepers were installed. The head was pulled apart and inspected by us as well as our atv machinist. All was brand new and within spec of what we were using.
There is absolutely no engine noise what so every it just lacks power in my opinion and bogs off idle. The motor was built using a factory honda 350x specific manual. All parts were installed checked and rechecked per the manual except for the camshaft and valve Trane.
We have adjusted the valves 2 times and change oil 3 times with about 3 hrs of run time no signs of metal. We run 110 and Brad penn 20w50 oil per the cam grinders request.
Goki starter will not turn the motor over without the decompression cable installed and working correctly. However when the decompression lever is engauged it spin the motor over fast and free.
On the valve Trane cam lube was used to install all components.
