Keen sert also called time cert will likely be too big. Helicoil will be better.
2 thing I have had luck with
Use a Dremel with fiberglass reinforced cutoff wheel. Cut a slot across the middle of the bolt and turn it out with a flathead screwdriver. Don't worry about cutting into gasket surface a bit. It won't effect anything.
After you drill it, thread it a slightly bigger standard size. You can't go next size bigger in metric cause its too big. But you can often find a standard that still fits through intake holes but is bigger.
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
