Results 1 to 8 of 8
Thread: 85 250r bracket
    Jul 2014
    Lloydminster, Alberta
    503
    85 250r bracket
    Recently bought a 250r and these brackets came with the bike, guy was unsure where they went, any ideas?Click image for larger version.
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Jan 2011
    Choctaw, OK
    2,755
    Those are part of the radiator frames.
    Jan 2011
    Choctaw, OK
    2,755
    See the pic
    Las Vegas, NV.
    2,487
    Quote Originally Posted by Samjp22 View Post
    Sure do. Those brackets go from the bottom, rear, radiator mounts to the front tank mounts. Here's a pic, since those are worth a 1,000 words. I just happened to have my radiator shroud off, as I was repairing a few cracks in the shroud.
    Jul 2014
    503
    Awesome thanks guys! Do you guys know where I could get some front seat rubbers by chance?
    1984 ATC 70 x2
    1985 ATC 250R-stock
    devore,ca
    1,016
    Can you post a pic of the crack repair in your shrouds ?. Mine are pissing me off !
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Las Vegas, NV.
    2,487
    Here ya go Bob. I'm sorry I didn't take any "before" pics of the cracks. Hopefully this will hold up to the test of time. The crack in the top of the shroud was opened up about 1/16" before the trip to Dumont Dunes this last weekend, and it had been that way for quite a while. During the ride, I noticed it was getting worse, and by the end of the day, it had opened up to about a 1/8" gap at the top edge. The shroud's bottom hole had been cracked for quite a while as well. The bolt was still in the tank, but there was no plastic in the area of the bolt to secure it to the tank. You could pull the bottom part of the shroud (by the bottom bolt hole) away from the tank as the shroud was only being held by the top 2 bolts, so I decided to have a go at repairing both cracks when I got home. Epoxy was used to repair both cracks, and the plastic was roughed up for adhesion purposes.
    The top crack was constantly spread open when relaxed, so first I squeezed it back together, and melted the plastic together in a few strategic areas with a heated screwdriver. Second, I put a coat of epoxy around the repaired area. Then I reinforced the area with piece of bailing wire, which was wrapped around the repair and laid into the epoxy. Finally, another coat of epoxy was put over the wire, completely encasing it.
    The bottom crack was repaired with a piece of plastic, which was cut from an old 350X headlight bezel. It was cut to shape and then epoxied into place over the broken area where the bolt goes. Additional epoxy was then spread over the entire repair area. After the epoxy had cured, a new bolt hole slot was drilled in the repaired area.
    Unfortunately, due to clearance issues between the tank & shroud, the epoxy can't be too thick otherwise the shroud won't fit right. So, hopefully the epoxy isn't too thin, and cracks immediately, or just doesn't adhere good enough to the plastic. Only time will tell.
    Attached Thumbnails Attached Thumbnails Shroud1.JPG   Shroud2.JPG   Shroud3.JPG   Shroud4.JPG
    devore,ca
    1,016
    My brand new oem's lasted about an hour before one of the holes cracked. I may epoxie the back side of all the holes to help keep the rest from cracking.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
