Hi, I'm new to the forum and need some advice on tracking down an issue.
I just put a new carb (Chinese aftermarket) on my 200s and now it runs fine. However, the light don't work. But I do notice that the bulb filament faintly glows when it's running. It's so dim, you can hardly tell, but it does glow. It has been like that for years, but replacing the carb was the priority then. I checked connections, and the ground screw by the cdi box(if that's the right term) and everything looks OK. It is in very nice shape, it's not like it sat outside or anything like that, causing corrosion. I researched everywhere online to no avail. Any help would be much appreciated, thanks in advance!
