Results 1 to 3 of 3
Thread: Similarities between 1986 ATC 250r and TRX 250r?
    Aug 2014
    Denver
    20
    I'm just wondering what major parts are interchangeable between these two ATVs. Also, what of those parts are also interchangeable on the ATC 250r?
    Can I put an ATC250r pipe and silencer on a TRX?
    I'm asking because it seems like I can find an '86 trx for much cheaper than an ATC 250r, which might be better for me right now. But, I'd like to be able to use it as a parts machine later on, when I can afford an ATC 250r. I'd also like to be able to buy add-ons for the TRX, like a pipe and silencer that I can switch to an ATC.
    Thanks in advance!
    Dec 2007
    Quebec,Canada
    1,014
    Engine will swap,swingarm parts if I'm correctmaxle,caliper......
    All exhaust part are different.
    The silencer is very similar and can be fitted easily
    The front pipe will not fit
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    devore,ca
    1,050
    Im running a trx engine, so I know it works. I think some of the trx rear end stuff will fit the '86 atc but not the '85.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
