Well I picked up a 1983 200x on Thursday I traded it for a mossburg 22 that I had picked up in September in trade for a 1983 klt 200 that I had picked up for $85.
I got it running last night after cleaning the carb, changing the stator out and the spark advansor. But it runs kinda funny, after running for about 3 seconds it starts to rev higher almost like it was at 1/4 throttle. When this happens the throttle is not pressed at all. I have checked and the cable is not catching or keeping the slide open. I saw my friends 200x do something similar before but it had to do with the cable routing after he installed a front number plate, unfortunately this is not the case with mine. I'm kinda thinking it could be an air leak but I haven't had time to spray the motor while running with staring fluid. The motor also smokes I'm assuming valve seals because it still starts and runs so the rings should be ok.
It's been a while since I had a 200x so any extra thoughts or opinions would be helpful. I'm trying to build this trike up so my 12 year old can start racing MX with us here in Arizona.
