Thread: 1986 and 1987 atc 200x differences
    Jul 2012
    Ohio
    83
    I wanted to come up with a list of differences between these two machines, here is a list of the ones I can think of off the top of my head. If I have missed anything, please add to it.
    1987 1986
    red swing arm gray swing arm
    white tank shrouds red tank shrouds
    painted cylinder fins polished cylinder fin edges
    ATC on rear fender 200x on rear fender
    Honda atc200x on front fender 200x on front fender
    no honda emblem on lower triple tree honda emblem on lower triple
    key switch/ dash no key switch
    nothing on side of seat atc on side of seat
    large kick starter rubber on fender small kick starter rubber
    large kick starter shaft diameter smaller
    p/v on tires pro vector
    fender brace clamps seperate fender brace clamps welded to brace
    seat latch/ fender brace yellow zinc painted red
    different fender brace to keep fender away from exhaust
    lips on rims are rolled lips are left open
    tire preasure sticker on rear fender none
    third gear is smaller larger
    rear upper engine hanger is white zinc painted red
    200x across tank honda wing on tank
    slightly different carb jetting
    paper air cleaner foam pre-filter foam filter, metal cage
    triple tree nut has flange and large hole for vent hose nut uses washer and has small hole
    200x on back of rear fender atc200x on back
    regulator has different plug regulator has two wire plug
    engine skid plate is larger is smaller
    gear shift plat is more heavy duty lighter duty
    no case saver case saver
    different clutch lifter rod
    3 is better than 4
    That's pretty dam good!! And I LOVE those 87 tank decals!!
    That 3rd gear slight change is not worth the compromise of the metal lost within the gear hub itself. I have 3 87 motors, all with "I don't know whats wrong with the gearbox??" I love buying those. And why can't every owner realize that the cranks have LH threads. I have about 8 destroyed RH threads that are backwards threads.
    Also, I HATE that gearshift plate!! It shifts so positive but it seems as if Honda hardened these just a bit too much. Did one year have shift lever "lightening holes" or was that both??
    Both years with that oil drain, thank you Japanese engineer!!
    Maybe the helmet holder was just one year; Maybe not, I forget!!
    I just glanced at your changes; I'm not sure if you mentioned the clutch disengagement bushing being different. The 87 has a shoulder on it so it sits within a seat to separate the plates when the clutch hand lever separates the clutch plates. EDIT, I see where you said "clutch shifter rod". I guess I didn't understand what "rod" meanted but it's just Cahb Pahts or "carb parts" LOL. These guys all bust my balls.
    Oil orifices in some dowel pins are changed to meter the oil flow differently, so wherever they are, the STUFF gets a bit more oil.
    The larger diameter large kicker shaft has round holes and thew other year has elongated holes (forget which year is the one people want. But, I have bored a clutch case for the larger shaft and got a stock rubber coated seal sizes at my bearing shop so I didn't have to open that hole too.
    The decompression seal is DC'd so my bearing shop gets me rubber coated dual lip seals that are 1mm less in width but the ID and OD are stock; and cheaper at the shop The clip for that shaft is gozo as well so I just use a regular circlid.
    I think I showed a few of those items if you google "3wheelerworld 20 day build"; Or stuff Dirtcrasher in that search, reword it and you can find it.
    I took pics mostly of the changes I'm fairly certain of.
    I wish Honda left ATC on the seat sides and Honda on the back. I only have 2 backups
    Did both years have the same fork boots number or accordions?? (lack of a better word
    Good ol Honda, always making tiny changes in hopes to improve it!! I love those valve eccentric adjustment changes; Best idea ever!!
    Honestly, when I build one, I never use the 87 3rd gear but always the kicker shaft and that seal I can buy. Opening that bore is chicken when you have a mill with an adjustable boring head; he he he he he he he !!!! 83/84 250R 35MM forks help allot as well!!
    You covered this awesome (and I think it should be a sticky), great job!!; I think I have just a couple more written down but I have to find my "swap" book to check it out. Extremely good information on your part!! You bagged it very well!! I personally say THANK YOU!!
    Arizona
    493
    Yes, agreed, Excellent job. Couple of more...
    The bushing where the rear brake caliper mount goes over that pin on the swingarm. On the 86, it has a c-clip holding it on and on the 87, it uses a flange on the back side so it cannot fall out.
    The front brake cable stay that comes off the triple tree, the 86 uses a bolt and the 87 uses a screw to hold the back on.
    The bushings on the engine skid plate are different. Hollow vs solid.
    The bolts that hold the handlebars on are normal dished-head bolts on the 87 and finished chrome bolts on the 86.
    The airbox lid on the 87 has a decal that says 'dry system' do not oil.
    The frames are actually different. The 87 has an extra threaded hole for the rear fender stay bracket that you mentioned above while the 86 bracket bolts up in the same hole as the exhaust.
    NEPA
    7,049
    Very well done fellas.
