Results 1 to 13 of 13
Thread: 84' Honda 200es Starter Question
    Jan 2008
    Willowbrook, IL
    856
    Went to start my ES today using the electric starter and all I got was a single click. Neutral light went out immediately after and nothing. Light went back on and tried it again only to have once again, a single click. So, my question is: Is the starter bad, or is there something else that I need to do or check? Or, do I need a new starter? And, if so, any suggestions on one? Thanks.
    85' Honda Big Red
    09' Yamaha YZ 250F
    2012 Polaris Sportsman 500 H.O.
    2015 Polaris RZR 570 LE/Trail Edition
    2017 Suzuki DR-Z400SM
    Crazyktmmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2014
    Idaho
    237
    Can always put power to the starter and see if thats it.
    Check and see if the battery terminals are tight/ clean
    If not take apart the starter button and clean the contacts.
    After that the starter solenoid might be acting up
    200x - I think I have 7 of em?
    10 70's
    3 350x's
    Tri Z
    225
    kxt
    and the 90 110 125m that I need to get rid of.
    YT175 with rear suspension sold
    200es- SOLD !!!!!!
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Start simple , make sure you have a good charge on the battery . Pull the rope , turns over ? Check the ground .
    Dec 2012
    812
    Off topic but what type of tires do you have on your rig?
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Jan 2008
    Willowbrook, IL
    856
    Kenda Bear Klaws. And, I love em'. Saw them on another member's BR and had to have them.
    85' Honda Big Red
    09' Yamaha YZ 250F
    Jan 2008
    Willowbrook, IL
    856
    Ok, so here's where I stand currently: I made sure that the battery is fully charged. When I turn the ignition to on, Neutral light comes on, headlight is on and then when I go to hit the start button, CLICK and the headlight goes out along with the Neutral light. About 5 seconds or so later, both lights come on again. I also tried using my winch which is directly connected to the battery and nothing happens other than the same issue with the Neutral and Headlight. Any ideas?
    85' Honda Big Red
    09' Yamaha YZ 250F
    Jul 2014
    Idaho
    237
    Connections are lose some where.
    10 70's
    3 350x's
    Tri Z
    225
    kxt
    200es- SOLD !!!!!!
    Jan 2008
    Willowbrook, IL
    856
    Quote Originally Posted by Crazyktmmatt View Post
    Obviously the battery connections are tight so any suggestions as to where I should start? This is not really my thing so I'm always learning as I go. Thanks, I certainly appreciate the help.
    85' Honda Big Red
    09' Yamaha YZ 250F
    Jan 2008
    Willowbrook, IL
    856
    Fully charged battery and when I go to start it, several clicking noises. Bad starter or bad solenoid? Suggestions or solutions? New starter or can I change the solenoid?
    85' Honda Big Red
    09' Yamaha YZ 250F
    May 2013
    St. Louis
    505
    I would guess that either the battery is bad , ( go have a load test done on it ) or you have a dirty or loose ground at the frame .
    Aug 2014
    South Louisiana
    1,915
    Use a flathead sd and jump the solenoid if your starter turns then you know it's the solenoid not engaging and go from there
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Agreed. The solenoid's are cheap as well.
    TF 07,08,09,10,11,12,13,14!
    Jan 2008
    Willowbrook, IL
    856
    I'll do a load test on my battery and go from there. Even though it shows a charge, I think that it may still be weak. But, I'm gonna go with the connections as well since the last time out I go it quite muddy. I'll give an update as soon as I can get a handle on this. Thanks for all the advice, I'm sure my troubles aren't over yet. I'll be back...
    85' Honda Big Red
    09' Yamaha YZ 250F
