Results 1 to 8 of 8
Thread: atc 110 engine help
    Aug 2014
    Quebec
    51
    atc 110 engine help
    i have a 1980 atc 110...i think my engine is not the stock 1980...i think now i have a 82 83 engine..how i can make the difference.i say that because i want to change the spark plug ...i found a ngk br7hs...i think is not the right one..1980 need a d8ha and 1982 1983 dr8sh.my tread size is 14 mm .thanks.
    Aug 2014
    Quebec
    51
    precision ngk d8ha for american model (12mm)
    ngk dr8hs for canadian model (14mm)
    DONT understand why previous owner try to use a ngk br7hs
    Oct 2013
    Wherever I May Roam
    3,757
    dr8hs is a 12mm plug.
    dh8a is a 12mm plug.
    Either will work for a stock 110.
    If your 110 has an ngk br7hs, a 14mm plug in it, theres a chance it has been drilled and threaded bigger as a repair. In this case, your newly puchased plugs will not fit.
    Aug 2014
    Quebec
    51
    yeah ...you right...now i put a br8hs whit 14 mm tread.i have some spark...i think is good.i check my timing points gap..but my 3 wheeler dont start.i think to low compression ...
    Oct 2014
    Edon, Ohio NW corner
    71
    1980 110 is points and condenser, 1981 and newer CDI electronic ignition.
    Aug 2014
    Quebec
    51
    yes my engine is the stock 1980 whit point and condenser..just my spark.plug hole was drilled and tread for 14mm.that why i was confused.
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by freak trike View Post
    is the plug getting wet or is it bone dry? Do you have access to a compression gauge?
    Aug 2014
    Quebec
    51
    plug wet ...i have to check my valve clearance beforebut if they are ok i will check the compression whit gauge.but if compression still low ...i think a have to rebuilt my top end
