Results 1 to 2 of 2
Thread: Need expert help, wont shift past 3rd when right cover gets bolted on
    Oct 2014
    Minnesota, United States
    Like the title says, its shifts good through all gears when the right-hand crankcase cover is off, but when you put the cover back on and tighten all the bolts down it will not shift above 3rd gear. Motor is out by the way. Im only the messenger here, my buddys are the ones working on it. The motor was taken apart and carefully re-assembled also.
    May 2009
    S.E. Michigan
    1,251
    What motor?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
