Results 1 to 14 of 14
Thread: Buying 250r rims
    Jul 2014
    Lloydminster, Alberta
    503
    Buying 250r rims
    Just looking for some feedback as to where is best to buy front and rear rims for a 1985 250r. what makes you guys prefer and offsets? thanks
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Jul 2014
    503
    currently looking at the douglas A5 wheel, is it better to go with the 8x8 3.0+5.0 of the 9x8 3.0+5.0? I'm no expert with rims and so if someone could explain the difference it'd be much appreciated
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Oct 2006
    2,502
    Quote Originally Posted by Samjp22 View Post
    For front rims you have the option of the 11 inch rim in either the original gold, from EBAY or otherwise. Douglas makes a chrome front rim but the 11 inch rim leaves one with limited tire choices.
    The other option is a 10 inch custom rim from xowner or from Douglas which opens up more choices for tires. Xowner does group buys and pretty sure Douglas does not stop production to make just one so it may require a batch. The Douglas 10 inch front rims may be on EBAY but I get mine from xowner.
    8x8 is eight inch rim, eight inches wide. 3.0 is the offset from the back of the rim flange to the outer edge or the rim, the 5.0 is the rim flange to the outward facing side of the rim.
    I assume the 9x8 is a nine inch rim as the offset is the same, and would require a nine inch tire. Where as the eight inch rim would require an eight inch tire.
    The style/brand of rear rim is really dictated by the terrain you ride and how you ride your machine.
    Jul 2014
    503
    Okay awesome! Thanks for the quick reply Mr. Clean! Really helping me out
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Jul 2014
    503
    And as for the front hub is it able to be sandblasted and re powder coated?
    1984 ATC 70 x2
    1985 ATC 250R-stock
    New2Tri-Z's Avatar
    New2Tri-Z is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2012
    Redding, CA
    380
    Yes it can. All bearing surfaces and thread holes will have to be taped off, plugged or cleaned up after powder coating. New wheel bearings and seals and you are back in business.
    Currently Owned
    1986 Yamaha Tri-Z 350???
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    2005 Polaris Predator 50
    2004 Polaris Predator 90
    2-Honda Trail 90's (need to be brought back)
    Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
    Jul 2014
    503
    Do you guys know the name of the 11' front wheel from douglas can't seem to find any on rocky mountain tav
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Oct 2006
    2,502
    Cannot find a new one, but found this tire/rim setup.
    http://www.ebay.com/itm/HONDA-ATC-25...62ece6&vxp=mtr
    Jul 2014
    503
    Douglas is still making 11x6 front rims, if anyone is looking to buy some you've gotta contact douglas rims and the part # is 017-02
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Jul 2014
    503
    would a 22x11-8 tire fit on a 8x8 rim or would it be better to go back to original size with a 9x9 rim and get 20x10-9 tires?
    1984 ATC 70 x2
    1985 ATC 250R-stock
    New2Tri-Z's Avatar
    Aug 2012
    Redding, CA
    380
    It will fit just fine. 22" is a little tall for my liking, but I like them wide. I personally would run the 20x10x8, thats what I run on My Tri Z and my 450R (paddles and holeshots).
    Currently Owned
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    I love the wheel set up Duncan put on Instagram
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Jul 2014
    503
    Damn those are nice
    1984 ATC 70 x2
    1985 ATC 250R-stock
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    22" tires are nice if you need the ground clearance. Or if you're looking to get the most top end speed out of your machine. It all depends on what terrain and style of riding you prefer.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
