I got the motor put in, Now I'm having issues with it running, 1st the carb pours gas out the bottom, Which i switched carbs, that one was better, but when I started it, its "skipped" while it ran, Idles fine, but as soon as you push the throttle it skips, Like the choke level being on. If you pull the choke (which i can't get the cable and handle got work exactly correctly) the skipping get worse and it stalls. I cleaned the "leaking" carb, and tried that one, that one ran better but still skipped a little.
Now it started leaking again. Im almost positive the carbs are causing the skipping, but should I look anywhere else as well?
Does the plunger pull out of the carb when choking?
