I agree that the "no gasket" thing never made me a fan. But, if I stone any high spots and epoxy and smooth any lows, 3bond each side, let it tack up and it hasn't failed me.
I know your searching for the other demon but don't forget the left crank seal MUST be pushed in about 5MM to pass the taper. Flush and you'll have an air leak so just check it.
I find the 250R to be one of the easiest bottom ends to build providing it's assembled properly. A plastic
taps it all together easy.
This is why I zip tie the tranny shafts when I tear them down. Time passes and things are forgotten...... I hope you get it!!
