Thread: atc frame
    Aug 2014
    Quebec
    51
    atc frame
    someone know if all honda atc 90 ...atc 110 ...atc 125m ...are mounted on the same frame.if not what is the difference .thanks.
    Oct 2014
    Edon, Ohio NW corner
    71
    Very similar frames, I have a 1981 110 engine in a 1985 125m frame and atc90 wheels. I used the 125 wire harness with just a few modifications.
    Cold Lake, Alberta, Canada
    3,016
    I can answer a little bit here. Not up on 110's and 125's too much. The US90 frame (1970-73) didn't have a removable front engine mount, I'm not sure about the 74 model. After that the 90 frame had a removable front engine mount. I put a 1980 110cc in my 1972/73 frame. The 110 is 6mm longer I believe so I had some trimming to do. There are going to be a lot of subtle differences once you start looking at air box hookups, axle/brake configurations etc. Can we ask what your plans are? Might help with a more definitive answer.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Aug 2014
    Quebec
    51
    i want to know if the hole for engine base mount are same for 110 and 125m.the engine base is not the same i think but i dont know.can i bolt on a 125m on 1980 atc 110 frame.
