Results 1 to 15 of 15
Thread: stuck in a rut
    dunn is offline New to the board Arm chair racerNew to the board
    Jul 2014
    Marksville louisiana
    11
    stuck in a rut
    I've had my 83 250r now for 4 months. It was bored .020 over and bogging out. I'm down to a 122 main but stayed at a stock 50 pilot. It doesn't bog nearly as much but I think I'm fouling plugs. A new plug in only lasts a hand full of rides. Do I continue going down on main how bout the pilot? I also adjusted the float level and set the needle clamp at top notch. Any suggestions would be appreciated.
    Sep 2011
    Ocean Beach, CA
    1,333
    Check your reeds. a broken reed pedal or a set of pedals that dont seal to the cage properly will give you what you think is a rich condition. change your reeds out and set that main jet back to a 132-137 (if its the stock 30mm keihin and you have no other mods), and give it a try.
    Jul 2014
    11
    Quote Originally Posted by manbearpig View Post
    I've changed the reeds out I'll give them a look see again. I do have the stock 30mm keihin. I thought I had to go down on the main due to running fat but I'll give it a try. Thanks
    Sep 2011
    Ocean Beach, CA
    1,333
    damaged reeds or a pedal that wont seal will give a false 'rich' condition. it will foul plugs if its really bad.
    If you're in Marksville, La, as your profile states, you're only 75-82 feet above sea level, depending on what website you ask. Thats not high enough by any means to warrant a small main jet (like a 122) to compensate for the less dense air of higher altitudes.
    Somethin is wrong fundamentally. set everything back to stock as best you can and start testing individual components.
    some questions that may help if answered: you state that plugs only last for a couple rides. how long are your rides? are you fouling a plug going up and down the street or are you fouling plugs while out on the trail after a 2 hour ride? what is your definition of 'fouled?' what is your definition of 'bogging?' does it bog mid range, only at high RPM, only down low?
    Jul 2014
    11
    It seems to be bogging at mid to high range rpms but the bog isn't very bad but it is noticeable. As far as fouling plugs I can put a new one in ride trails or a couple trips down the street pretty much burn a tank of gas and it's done. Yeah here in central Louisiana the humidity can be rough too. So you're saying check the reeds go back to stock main at 130 then go up from there.
    devore,ca
    1,042
    I had a carb that no matter what jet I put in it bogged-bad. It turned out that the carb was just plain wore out and not sealing around the jets so the gas was just going around the threads instead of being meetered through the hole in the jet.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Sep 2012
    chatham kent
    9
    What type of oil are you using?
    Jul 2014
    11
    Quote Originally Posted by renderX View Post
    I'm running 10w 30 gtx. I've also noticed gas in my air box tube as well.
    Jul 2014
    11
    I'm running 10w 30 gtx I've also noticed gas in the air box tube
    Sep 2011
    Ocean Beach, CA
    1,333
    Quote Originally Posted by dunn View Post
    he means what mix oil are you using in the fuel your run. would probably be good to know what mixture youre mixing at too (20:1, 32:1 40:1)
    Oct 2006
    2,504
    Or using motor oil as premix could be the issue
    Sep 2011
    Ocean Beach, CA
    1,333
    Quote Originally Posted by Mr. Clean View Post
    tired to give him the benefit of the doubt.. it would be difficult to be that far off base.
    Jul 2014
    11
    My bad on that I misunderstood. I'm running HP2 32:1 have had a couple of people say that 5 gallons per bottle is fine. Any opinions on that one.
    Oct 2014
    What do you mean 5 gallons per bottle? The premix is designed to be run at a specific ratio. The little bottles are 32:1 when mixed with one gallon. If you use a 5 gallon can and want to keep it 32:1 with the small bottles than you need 5 small bottles. One 32:1 in 5 gallons would make it, um, 160:1,if my math is right. Probably not enough oil in that.
    Oct 2014
    Indianapolis
    5
    Your math is correct. Way too lean if he's running one bottle/ 5 gallons
