I just bought this 225dx and went to change the oil today. The guy who had it before me must have tightened this thing with every bit he had. Anyway, I was putting pressure on it to loosen it and the bolt that loosens it snapped off completely and left a hole in the center.
How would you guys approach this?
I was either thinking tapping with reverse threads and putting a bolt in there (to try to remove the main plug and go back with an oem plug) or taking some measurement from an extra plug I have and using a dremel cutting wheel to cut a notch or two (without touching the threads) to break it apart.
To be honest I really don't know how to approach this so I thought I would try and get some info from you before I make this into a huge mess (crankcase damage).
Thanks!
to hit it in the CCW direction from the outer edges. The impacting should help loosen in, plus it should start backing out.
