I've been doing a bunch of things at once, and apparently I did one of them wrong.
On my 250ES I can't get it to hit a lick. No inclination or offering to fire.
The biggest contributing issues I think apply is I have rebuilt the carburetor, and replaced the timing chain.
While I feel stupid at the moment, I'm not a noob to small engines, I just feel I either misunderstood the service manual somewhere, or made some dumb mistake.
Best I can tell the root problem is there does not seem to be any fuel entering the combustion chamber. I sprayed a little Kroil in the chamber to keep it lubed while I turned it over setting timing, the plug still smells like that stuff, not fuel. I wonder if that might not be interfering, but I didn't put that much in there, and surely if fuel were entering the chamber it would ignite regardless, Kroil is mildly flammable itself, and should allow the gas to ignite.
I think I have spark, the plug fires outside, who knows what it's doing inside. (It is new.)
I have a compression stroke, and I am getting puffs out the exhaust. Apparently the timing is close enough that it is pumping air, although if it's pulling from the intake or not I guess might be the big question.
On the timing chain, I could not get the timing marks to align perfectly with the head. By that I mean a few degrees, not way off. I was within one chain link, slipping the chain just made it slightly off in the other direction.
I set the valve lifter clearance. But after cranking on it some it loosened up dramatically. I set the flywheel back to the timing mark and re-set clearance to .003", didn't change anything.
So basically I am not entirely sure where to look first, by all accounts everything "should" be good. I've never messed with a timing chain before, and wonder if I did not goof something up there. At the same time, timing a little off shouldn't prevent it from at least trying to hit, backfiring, or some sign of life. As for the carb, it's not my first carb rebuild. I've rebuilt everything from 4 barrel automotive carbs to lawn mowers, and I rebuilt a 250SX carb not a month ago so I was familiar with it already. I have a hard time believing I goofed it up so bad it won't run, but who knows.
Another thing worth mentioning is I have some kind of issue with my fuel tank petcock. But it's issue is sending fuel even when it's off, so I don't think there is any lack of fuel to the carb. I drain the bowl and it has gas in it, so it appears to be getting fuel (i.e. the needle valve isn't stuck.)
I'd appreciate any ideas at this point. I don't feel like tearing it down to the timing chain again if I'm really not sure that is it.
