Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: A Couple of Tuning Tips
    Miami,Fla.(305)
    808
    Maybe he took too many already?
    -Maybe you're right????
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Surprise, AZ
    2,428
    Anyone want to re-start with a couple of their own tuning tips?
    Lets help each other.
    Mexico
    9,018
    Quote Originally Posted by onformula1 View Post
    I volunteer YOU to go first!
    It sucks to get old
    Surprise, AZ
    2,428
    Here I go...LOL
    Think you want heavier clutch springs, but care about you left hand?
    You can mix stock & heavy duty springs and come up with a "Medium duty" spring set.
    ONLY do this if you have a even number of springs in your clutch set up. 4-6-8 evenly space them out.
    Don't try this on a odd set up like a 5 spring clutch.
    I know people that do it and say it works fine, but bench testing by pulling the clutch lever in & out why looking at the clutch assemble and you will see it off kilter. Don't risk the extra wear.
    Mexico
    9,018
    On dedicated asphalt drag machines we would pull the seals out of the wheel bearings and just shoot a little WD-40 once in a while instead of using grease.
    Some guys would have a member of their pit crew wiggle the brake calipers to loosen them up after the burn out to reduce drag.
    I always wanted to try filling my frame and tires with helium
    It sucks to get old
    Surprise, AZ
    2,428
    And if you use a standard chain over a O-ring chain or X-ring chain you will gain 1-2 HP on a crank dyno.
    Dec 2014
    Hoffman Minnesota
    135
    So on my 1982 200 big red the open side of the spark plug would face the front of the engine, or towards the exhaust header right?
    1982 big red
    1974 atc 90
    Life is hard, but its harder if you're stupid - John Wayne
    Surprise, AZ
    2,428
    Quote Originally Posted by thcowboy View Post
    Aye theres something called medical marijuana
    Yes, you got it.
    Mexico
    9,018
    I assume that would be only when the O-ring chain is cold, right?
    It sucks to get old
    Surprise, AZ
    2,428
    You don't use a chain on a "Crank dyno"...LOL
    Mexico
    9,018
    LOL! Got me good there!
    It sucks to get old
    Ronnie, told me and Mike DEEPa to use a good sharp punch and put like 5 evenly spaced dings in the lower case where that base gasket is.
    He said they do suck in and this was an easy fix!!
    Great stuff here guys.
    Just a suggestion, everyone take their brake calipers off and see how the slide pins are; Use silicone grease on those, It helps with drag and even stopping pressure!...
    Jul 2003
    indiana
    892
    Don't know if this had been covered as I didn't re-read the thread. But when you put together your front end put your,trike on a stand leave all parts loose, place on ground and give it a few good rolls and compressions and lift it back up and tighten up yer front end. Learned that one from my suspension guy on mx bikes. Really does make a difference.
    Surprise, AZ
    2,428
    Good mod, on big bore or high compression engines we equally place divets with a automatic punch on the base and head sealing surfaces (4 surfaces total)
    No more blown gaskets.
  15. #30
    Surprise, AZ
    2,428
    Quote Originally Posted by 90nut View Post
    That works great, I tap a short flat screw driver between the pinch slot, put the bike/trike on the ground, hit the front brake and compress the forks a few times, pull the screw driver out and torque everything.
