Results 1 to 8 of 8
Thread: Are the 250 big red trailer hitches the same as 250 sx hitches?
    Maine
    463
    Im thinking about getting on off a 250 big red and put on my sx. Its in good shape with no rust. I heard some people say they fit but the big red one is longer...True or false? Thanks
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Went and looked at mine . The bolt pattern between to two looks to be the same . Lower shock mounting is different and a cut out is provided in the ES hitch while the SX has a solid top on it . I would guess that the ES hitch would bolt up to the SX , but not the other way around .
    Feb 2008
    Pennsylvania
    2,306
    My 85 250sx has a 250es hitch on it. Fits it fine.
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    Feb 2013
    Senoia, Ga
    635
    The es hitch bolts up fine, but is a tad longer, and does have a slightly different downward angle to it as compared to an sx hitch.
    New york
    583
    both are the same, fit it in just fine with no issue
    Maine
    463
    Thanks for the replies.
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    KLT 250 Prairie
    May 2013
    St. Louis
    505
    They are not the same . The Es will fit the SX , the SX will not fit the ES due to the location of the lower shock mount on the ES .
    Aug 2007
    Montana
    857
    Quote Originally Posted by Chopsaw View Post
    That is correct I did the ES just because its longer!!
    DO the Best With What you got !
    My Feed back :cool
