That oil is 4 wheeler specific. You need to find an oil that has a three wheeler on the bottle.
It sucks to get old
Barnett is no longer here. He is the only one with the real opinion on oil.
Seriously though. Did some forum searching here and didn't really find anything specific.
1985 ATC 70
1985 ATC 250SX
1985 ATC 250R
I always put honda oil in my 250 sx,s. Never tried or heard much about that oil..
Current Trikes
2 1985 Honda 250sx
1985 Big Red
2 1983 YTM 200k's. 1 for parts.
KLT 250 Prairie
1982 Honda 185 - Waiting to be saved
1985 125m Parts Machine
Still on the hunt for a 1986 350x and 250r.
I've always ran Shell Rotella 15w40 in my 4 strokes and I've never had any issues.
I usually run Honda Gn4+ 10w 40 motor oil. or regular motor oil thats what all my manuals say. never had a problem in fact our atc 200 that we have had since brand new has had its first rebuild and everything on the inside looked brand new only problem was the rings were worn out.
Where the hell did Barnett go? Did I miss something?
The govt recruited him to write the details for the obamacare bill.
http://m.townhall.com/tipsheet/guybe...tions-n1532069
Proudly NOT a member of
"Team on the Teat"
1978 ATC70 w/ Piranha 140cc
2017 YZ 250x- Braap
I've run nothing but Shell Rotella T in all my horizontal engines for years, and never had an oil related meltdown. The clutches also last longer if you change the Rotella out every other ride, or every ride if you're beating on it all day I found. Sometimes it's a pain, but I haven't had to change the clutch on my china quad yet (100+ hours now!).
I've run Lucas and Maxima in my built up Suzuki DR125s and 200s with no issues either, but the Maxima ran an average of 5 degrees cooler.
Basically, it is formulated for our motors and is a reputable brand, so it should be good. The API SG rating is good. This is an older spec from back when there were more anti-wear additives in oil, which our engines benefit from. The newer API ratings (higher letters like SN) remove some of the good stuff from oil that we need, but is bad for modern car's emissions systems.
Do some google searching for ZDDP.
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
Only thing I have used in mine is Golden Spectro.....cause I like to spend a lot of money on oil.
That's always what we used in the 80s so I just keep with the same brand.
"See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
Trikes:
1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
Quads:
1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
