Results 1 to 15 of 15
Thread: Lets talk oil
    Dec 2013
    Earp
    29
    Lets talk oil
    So whats the opinion on this oil:
    Looking to run it in the following:
    Engine for 85 Honda ATC 70
    Engine for 85 Honda ATC 250SX
    Transmission for 85 250R
    Thanks!
    1985 ATC 70
    1985 ATC 250SX
    1985 ATC 250R
    9,020
    That oil is 4 wheeler specific. You need to find an oil that has a three wheeler on the bottle.
    It sucks to get old
    Mar 2013
    Central PA
    2,362
    Barnett is no longer here. He is the only one with the real opinion on oil.
    Dec 2013
    Earp
    29
    Is this better??
Name:	3 wheel lucas.jpg
    1985 ATC 70
    1985 ATC 250SX
    1985 ATC 250R
    Dec 2013
    Earp
    29
    Seriously though. Did some forum searching here and didn't really find anything specific.
    1985 ATC 70
    1985 ATC 250SX
    1985 ATC 250R
    Maine
    463
    I always put honda oil in my 250 sx,s. Never tried or heard much about that oil..
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
    Dustin87R is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2007
    Maysville, Georgia
    192
    I've always ran Shell Rotella 15w40 in my 4 strokes and I've never had any issues.
    Jan 2014
    La
    1,062
    I usually run Honda Gn4+ 10w 40 motor oil. or regular motor oil thats what all my manuals say. never had a problem in fact our atc 200 that we have had since brand new has had its first rebuild and everything on the inside looked brand new only problem was the rings were worn out.
    Jan 2011
    Choctaw, OK
    2,755
    Where the hell did Barnett go? Did I miss something?
    na
    5,702
    Quote Originally Posted by Flyingw View Post
    The govt recruited him to write the details for the obamacare bill.
    http://m.townhall.com/tipsheet/guybe...tions-n1532069
    Proudly NOT a member of
    "Team on the Teat"
    O.C., Oregon
    921
    Quote Originally Posted by Dustin87R View Post
    This. Shell rotella T 15w40 in all my toys. Good oil for cheap!!!!!!!!!!!!!!
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    I've run nothing but Shell Rotella T in all my horizontal engines for years, and never had an oil related meltdown. The clutches also last longer if you change the Rotella out every other ride, or every ride if you're beating on it all day I found. Sometimes it's a pain, but I haven't had to change the clutch on my china quad yet (100+ hours now!).
    I've run Lucas and Maxima in my built up Suzuki DR125s and 200s with no issues either, but the Maxima ran an average of 5 degrees cooler.
    9,020
    That explains the 73 page ZZDP supplemental benefits section.
    It sucks to get old
    May 2009
    S.E. Michigan
    1,251
    Basically, it is formulated for our motors and is a reputable brand, so it should be good. The API SG rating is good. This is an older spec from back when there were more anti-wear additives in oil, which our engines benefit from. The newer API ratings (higher letters like SN) remove some of the good stuff from oil that we need, but is bad for modern car's emissions systems.
    Do some google searching for ZDDP.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jul 2012
    Penfield NY
    660
    Only thing I have used in mine is Golden Spectro.....cause I like to spend a lot of money on oil.
    That's always what we used in the 80s so I just keep with the same brand.
    "See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
    Trikes:
    1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
    Quads:
    1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
