Thread: Removing brake hub and sprocket hub off 86 kxt 250
    Mar 2003
    NJ
    911
    man, what a pain it was to get the wheel hubs and axle nuts off. they were all rusted on like crazy. now i need to remove the brake rotor hub, the bearing carrier, and the sprocket hub.
    any ideas on how to remove these?
    it has been really bad getting this stuff apart. does everything slide off the end that had the nuts? i left my books at another house.
    thanks,
    mark
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    Sep 2003
    138
    Re: Removing brake hub and sprocket hub off 86 kxt 250
    Quote Originally Posted by sportvette
    thanks,
    mark
    one of them comes off right when you take the axle nuts off(i'am pretty sure its the brake rotor. leave the left side wheel on, get a block of wood on the right end of the axle (after removing the wheel hub) then hit it with a until it slides outta the bearings. to get the sprocket hub off i took 2 two ton jacks, put them on the tires and pumped them both at the same timeuntil it slide off....(home made press )
    May 2002
    Texas
    2,670
    After removing the right hub off the axle, You take the two main axle nuts off. the brake carrier and disc should slide off. then the axle slides out of the carrier from the sprocket side. It will probably take some persuasion since it's sounds like things are in poor condition. Do not beat too hard on the end of the axle as you can bend the whole thread area on the end. If you can, get a piece of pipe that will slide over the threads and butt up against the axle where the hub butts up to drive with.
    Dont remove the sprocket hub off the axle unless you have to. It's held on by an internal ring around the axle and underneath the sprocket hub. It can be a bear.
    Use buykawasaki.com schematics. much better than going it alone.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Mar 2003
    NJ
    911
    this stuff is really rusted on there. i had to use a 4 foot long bar with a ratchet head to remove the axle nuts on the end, and it still wasnt easy. then i had to zep the wheel hubs. bang them off like hell with a . then take a 3 foot plumbing wrench on the other axle nuts. needless to say i need new axle nuts from destroying them with the plumbing wrench. are the axle nuts still available through kawasaki? do other axle nuts fit this axle?
    the brake rotor hub does not simply come off. in fact it looks like it is going to be the worst to remove. i have some zep on it right now. im going to see if my dad could take it to work and press these parts off. is there any concern with getting the sprocket hub off with the press? i need this hub for my durablue axle. anyone have these hubs for sale?
    thanks,
    mark
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
