Results 1 to 8 of 8
Thread: How to clean Honda air cooled engines?
    110 atc's Avatar
    110 atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    green bay
    238
    My silver Honda engines have mud stains from the years of use. I'm looking for a way to get the grime out of the cylinder and head fins and leave a nice finish. Any suggestions?
    1982 110, 1982 Big Red, 1983 70 Christmas Special X2, 1983 185s, 1984 200s, 1984 200m, 1986 250r, 1987 125m, 1987 lt500r x2, 2003 Rincon, 2008 700xx, 2016 pioneer 1000-5
    Mar 2013
    Central PA
    2,362
    I buy a cleaner called purple power, you can even get it by the 5gal buckets. you can dilute it for different applications, but put some in a spray bottle and let it soak for a little, and if you have access to a heated pressure washer that probably wouldn't hurt either.
    I even use it as an alternative to clean carbs. Works great. Maybe someone else can vouch for it.
    Sep 2011
    Ocean Beach, CA
    1,333
    i find that the "Purple Power" product in straight, undiluted form, leaves a film on components, even after pressure washing off.
    i mix Purple power with simple green and dilute that down with water in a spray bottle. seems to work very well with no film left afterward
    Oct 2006
    2,502
    Quote Originally Posted by manbearpig View Post
    Straight purple power is caustic. Dilute it for sure. If you do apply it undiluted spray it with wd-40 or break out the polish and wax....have fun with that.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    I have used a soda blaster with great results.
    Mar 2014
    New Brunswick, Canada
    147
    X2 on the soda blaster. They are great.
    Slidell, LA
    4,738
    Eagle one aluminum cleaner
    110 atc's Avatar
    Nov 2007
    green bay
    238
    All right! I'll try some of these tips.
