My 1980 ATC185 has original tire in front and two newer tires in back. They are the typical square knobby tires. I need a little more traction to pull logs out of the woods for fire wood. Are there good snow tires that would make a considerable difference or should I look into chains? Where's a good source for chains?
Also, the rear tires look smaller than the front. But they have the same size on them. Is it just a optical illusion or do they run larger tires on front?
Thanks.
