Results 1 to 15 of 15
Thread: SX/ES Stator Swap?
    Austin, Massachusetts
    1,591
    SX/ES Stator Swap?
    will an SX stator swap out with an 85 250ES? i know the engines are similar but not sure if the stator/flywheel are the same. Any thoughts?
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Jan 2011
    Choctaw, OK
    2,755
    It should swap ok. The parts fiche now shows a common part number for both 85 models.
    1,591
    you da man! thats what i wanted to hear. thanks. did it change in 86?
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Mar 2011
    Red Lion pa
    1,542
    I would be careful though....There are different part #'s within the 85 model yr. May change the pulse coil connections.
    http://www.partzilla.com/parts/searc...TOR/parts.html
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Oswego NY
    1,935
    86 has a different end from stator.. and different cdi..
    New England Ride 4/13
    Miami,Fla.(305)
    808
    There are 2 makes of the stator which have different size flywheel & stator from what little I know about the SX/ES. Pretty sure- if your swapping-& If theyre different -you must swap flywheel along with the stator or vice versa (as a set) And- Im not sure though if its a yr. to yr. or model to model thing or what? Or it could have come with either??? Hopefully someone can clear this up?
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    3wheelrider you are correct you can use stator but need flywheel and I always use the sx cdi with sx stator or es with es
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Jan 2011
    Choctaw, OK
    2,755
    Ya there are several different part numbers associated with the stator but the current one is listed for both models. I also agree that the flywheel that goes with the SX stator you intend on using should swap over as well. In 86, Honda did a slight redesign to the stator, flywheel, and one way bearing. The change to the bearing is what drove the redesign of the stator and flywheel.
    1,591
    ok. i had a bad seal on the shift shaft and a bad stator. i changed out the case cover with an SX case that i know had a good stator. she fired right up and runs right. lights work. would i know right away if it was mismatched, or would it be something over time where a problem would arise?
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Jan 2011
    Choctaw, OK
    2,755
    No you are good to go. No further actions required.
    Oswego NY
    1,935
    If it works you should be all set!
    Ride it!! Lol
    1,591
    this site is the best. thanks boys.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    1,591
    OK, update. And HELP needed. my cousin, (and inactive member on here) bought an 86 250ES a few years ago. Good shape, but had previous owner said it had a bad stator. Well, we put a battery in it, and sure enough it would draw until the battery was dead. We bought a used stator from eBay form a guy in maine. swapped it out and it was the same problem. after that, he just kind of lived with having limited headlight range as well as e start. when the battery died, he had neither. well, move forward a few years and he asks me to address a broken shift return pivot bolt and leaky shift shaft seal. so, now i had a known good stator from an 85 sx. i swapped out cases (and fixed the pivot bolt). Everything seemed ok, but after a ride on friday, by day's end, dim headlight and no e-start. I'm stuck. but, i'm thinking that there may be a difference between 85 and 86 rather than a difference in ES and SX. Does anyone have a known good 86 ES stator? is there an option to buy a new one? Is there something other than the stator that would cause the problem?
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    6,798
    Possibly a bad RECTIFIER / REGULATOR or a broken wire in the harness . See if you have higher voltage when the motor is running than when not running . Check it at the battery terminals
    Quote Originally Posted by redsox View Post
    1,591
    ok, i'll try and get to it tonight. i'll report back. i tried to do it earlier but dead batteries in my meter.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
