Results 1 to 13 of 13
Thread: 1986 250r frame
    skidoo99 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    nh
    267
    1986 250r frame
    hey all, was wondering if the 85 and 86 250r frames are the same? what is different?
    thanks
    O.C., Oregon
    921
    On an 86' frame the motor mounts are different(Welded vs. bolted), slightly different rake angle (Less). Not much changed frame wise. The rake was the main thing.
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Las Vegas, NV.
    2,516
    Quote Originally Posted by 250rRoostmaster View Post
    Which motor mounts are these?
    The only differences I know of are the rake, the forward gas tank mounts, the rear taillight mounts, and the rear shock reservoir mount is welded on ('85), and bolted on('86).
    Nov 2010
    nh
    267
    i tore it down to the frame today and its a 12/86. here are some pics. my gf's father owns a frame repair shop and said it would be no problem to straighten it. all i need to do is bring the beer haha. could someone send me some close up pics of a frame preferably bare but if not either will work, just so i have something to go by when he welds new mounts to it. also, i am in dire need of the triangle shaped motor mounts for the front of the motor by the exhaust. if i can get ahold of these i can mount the motor in position with these and the rear swinger bolt. thanks guys for the help. this turned out to be a bigger project than i thought but it will be worth it in the end!
    Attached Thumbnails Attached Thumbnails unnamed.jpg   unnamed.jpg   unnamed.jpg   unnamed.jpg   unnamed.jpg
    1973 70
    1984 70
    1986 250sx
    1986 250es
    1986 250r
    O.C., Oregon
    921
    The forward most lower mounts or "triangle shaped mounts" as skidoo put it in the above post, the 85 has the welded nuts, 86 does not ..
    2017 YZ 250x- Braap
    Oct 2012
    WI
    499
    Wow that frame is in very tough shape. I would try and find a nicer one.
    1983 ATC 200x
    1982 ATC 250R X2
    1983 ATC 250R : Future build
    1985 ATC 250R : Main rider
    1985 ATC 363R Duner
    1985 ATC 250R X2 : Future build
    1986 ATC 250ES
    Las Vegas, NV.
    2,516
    Good luck with that frame. The previous owner(s) really did a number on it.
    ...the 85 has the welded nuts, 86 does not ..
    Gotcha. I misunderstood what you were saying was welded on.
    Nov 2010
    nh
    267
    so what you mean is that the 86 had a longer bolt with a nut on the other side.
    1973 70
    1984 70
    1986 250sx
    1986 250es
    1986 250r
    Nov 2010
    nh
    267
    ya she is in rough shape but i really wanna ressurect this. i have the guy to fix it just in need of those mounts for the front of the frame. i think it would be pretty cool to bring it back to life, i hate how ppl just chop these things up not knowing what they are doing
    1973 70
    1984 70
    1986 250sx
    1986 250es
    1986 250r
    Jul 2014
    Lloydminster, Alberta
    503
    from what i can see on the parts diagram the servicehonda.com provides for the 85 and 86 models all the motor mount bolts are the same between the years
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Oct 2006
    2,504
    Here is a pic from EBAY with the nuts welded to the right frame mount which is the 85 style.
    skidoo what are you going to do about the lower motor mount brackets on the cradle and the upper mounts that were removed? I have a frame here that the backbone is bent severely but shipping is not cheap for a frame.
    I may also have the front motor mounts, will check when I get in the garage this weekend.
    Jul 2011
    Colorado
    141
    skidoo,
    What motor are you planning on using in this frame?
    Your other post with photos of your trike looks like a CR250R motor is stuffed in there. Explains why the frame was hacked up.
    Think a few photos of the motor would help to show everyone what you are dealing with. If you plan on reinstalling that motor you will need to fab up some other motor mounts.
    The first photo with parts in other post shows the right half of a ATC250R lower. Compare it with the complete motor and you will see the difference in motor mounts requirements.
    Nov 2010
    nh
    267
    the previous owner did hack up the frame and installed a cr motor. I plan to put the stock r motor in it which I have. I'm going to weld motor mounts back on the back bone for the head and the lower ones. Just need the front mounts to line up the motor
    1973 70
    1984 70
    1986 250sx
    1986 250es
    1986 250r
