Results 1 to 15 of 16
Thread: 250sx swingarm bolt sizes/dimensions?
    Worcester, MA
    1,117
    Does anyone know the dimensions and sizes (length, thread, pitch, etc) of the 250sx swingarm bolts and the locking nuts?
    Thanks
    Jan 2011
    Choctaw, OK
    2,755
    Which bolts specifically? The 6mm stuff is all 1.0 thread pitch and 8, 10, and 12mm stuff is all 1.25 thread pitch. As far as length goes, we need to know which bolt(s).
    Jan 2011
    Choctaw, OK
    2,755
    These might help. The special bolts like the ones that bolt the right side of the diff to the swingarm are "Special" and they don't give dimensions for those.
    http://www.servicehondapsn.com/fiche...85&fveh=131334
    Worcester, MA
    1,117
    Ah, that's the one I was hoping for. Can't seem to find a cheap set and lost the last few sets I had. Was gunna just make some up but didn't have one to replicate. (Part 15, the pivot bolt)
    Jan 2011
    Choctaw, OK
    2,755
    The "Special" is 10x25 with a larger flared head than standard. What do you want to know about the pivot bolt? I have one right here.
    Jan 2011
    Choctaw, OK
    2,755
    Oh lookie!!!!!
    Worcester, MA
    1,117
    I wanted to make the pivot bolts from scratch. Didn't know the thread and shoulder length/diameter.
    Jan 2011
    Choctaw, OK
    2,755
    Give me a minute
    Jan 2011
    Choctaw, OK
    2,755
    This get you started?
    Attached Thumbnails Attached Thumbnails 100_1853.JPG   100_1852.JPG   Slide1.JPG
    Worcester, MA
    1,117
    Perfect! Wow, thank you!
    Jan 2011
    Choctaw, OK
    2,755
    I'll keep it close in case you need any other info off of it.
    Worcester, MA
    1,117
    Maybe just the thickness of the locking nut. I'm sure I can make it use any tool to loosen and tighten instead of the oem pattern. You are a life-saver!
    Jan 2011
    Choctaw, OK
    2,755
    Here ya go
    Jan 2011
    Choctaw, OK
    2,755
    The height on the locknut is .43"
    Worcester, MA
    1,117
    Thank you!
