Thread: Removing the rear brake drum on a atc 70
    I tryed to take the drum off but i cant get it off the manuel says its slides right off i messed with the brakes thinking maybe it was hanging up on the pads and nuttin wont budge,anyone know anything about this the manuel dosent really say alot.
    1983 Honda 110
    1967 Mustang
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    it must be rusted ,, cause they just slip off. maybe pull the axle out the other side it will go either way,,,,,,,
    It wont budge lol its very rusty i tryed for a while to get it loose nothing worked so i put everything back toghter and shortened the pull o welp.
    1983 Honda 110
    1967 Mustang
    KASEY's Avatar
    4,248
    put off today what you can do tomorrow!!! ,,, if you can get the sprocket off and fill the seal cavity full of grease maybe it will help to work its way thru the rust and help you when its time to tear it down,,,, someday you will have to pull it apart,,,
