Results 1 to 10 of 10
Thread: 250es speedo gearbox, plastic internals?
    Mar 2003
    Australia
    1,919
    So after 10 years of looking I finally got my hands on a speedo, cable and gearbox to suit my 250es over here in Australia. It's off an old farm bike but appears to be in ok condition (still in the post on its way). I had to convince the guy and offer him a heap of money to sell the stuff on its own as I couldn't afford to do the 26 hour round trip to pickup the wreck. Anyway, he told me he couldn't get the axle out, very typical for this machine I know! He told me he just cut the axle either side of the speedo gearbox. So looks like I'm in for some work to get it out now to put on my bike. My question is, are there any plastic internals in the gearboxes that I should look out for when applying some heat, or is it all aluminium and metal gearing? Anyone else had this same problem? I am so chuffed that I finally found a genuine ATC one with km/h. 10 years in the making. Thanks blokes
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Apr 2002
    s.w. michigan
    6,498
    Well you are gonna cook any grease out and melt a o-ring or two heating it. I would recommend pressing it out.
    http://www.3wheelerworld.com/showthr...)-reproduction
    Feb 2014
    Victoria,Australia
    878
    Is that off that 250es in SA for $100?
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Mar 2003
    Australia
    1,919
    Yeah it was the one in SA. Was a good but that bike if only it wasn't far from sydney. Thanks John. are these a sealed unit or can they be pulled apart and serviced?
    Apr 2002
    s.w. michigan
    6,498
    Yes, like the pictures show they can be taken apart + "serviced". Really I have found just forcing grease into the little set screw hole area (down towards bottom of gear drive assemebly ) is all that is really needed.
    If the speedo drive turns over as it should no need for full disassembly.
    If it "skips" a cog the cast iron inside gear is missing a tooth and no sence it taking it apart IMO since it is scrap.
    Apr 2002
    s.w. michigan
    6,498
    Well scrap may not be the correct word to use. Perhaps unusable may be better verbiage.
    I should review making just that one beveled gear. The one that rust off teeth,,,,,
    Mar 2003
    Australia
    1,919
    Thanks for the replies. Well just see what I'm in for when it arrives. Just noticed that my hub does not have the little tab that spins the gearbox. Bummer!
    Feb 2014
    Victoria,Australia
    878
    Hey John or Matt do either of you know what makes it miles or km is it the speedo or gearbox? so can you use a mph gear box with km speedo? would it be mph or kph?
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Mar 2003
    Australia
    1,919
    No idea mate, I reckon it may just be the speedo head to be honest.
    Apr 2002
    s.w. michigan
    6,498
    Yes, the drive gear is just the drive gear,,,, it don't care if it is turning a KPH or miles per hour head.
