Thread: 200x oversized handlebar help
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    I'm looking at handlebar options for my 200x build. I'd like to put oversized Pro Taper or Renthal bars on it. Would like to know what bend others are using and
    if solid or rubber mounted adapters would be the preferred mount.
    Thanks
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    1,641
    Pro Taper actually sells adapters for such a application.
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    I have a pro taper ATV mid bar on my 200x. It's 7/8" so not oversized but I really like it. About same bend as the renthal bar on my 350x. Both are very wide and comfortable. I'm 6'6" so my knees stick up quite a bit and the handle bars don't hit my knees when I turn.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    bandito90's Avatar
    Pa
    284
    I appreciate the input. I'll need to try to figure out what bend would best suits my 5'7 frame. I'll probably need to go with the solid mount adapters.
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Mar 2013
    Wausau, WI
    147
    I have the Pro Taper cr hi bend 7/8 on my 200x. I'm about 5'7 and they fit me pretty good could be a tad higher though, next time I would get the ATV mids. As far as getting the oversized bars I'd save my money and get the 7/8. I've rolled it quite a few times with them and have never bent them.
    1,641
    I have the Pro Taper Contour High Atv Bend.I would make not to get something without too much bend back on a 200x.You might have trouble with the bars hitting you.
