Results 1 to 2 of 2
Thread: Snorkled the Big Red!!
    Nov 2013
    NB canada
    67
    So I thought I would share this because I haven't seen anyone snorkle like this.. Ive only seen the ones coming out of the back which kinda seems in the way! So I used a vacuum hose because it was flexible and is stretchy.. fitted it between the fork and head tube of the frame! works perfect. Had it deeper then the stock intake with no problem. Also the crank case vent and carb vent were moved higher. Had it like this since summer and no signs of wear on the vacuum hose!
ID:	205186Click image for larger version.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Eureka! That is a great idea!
