Results 1 to 8 of 8
Thread: Kazuma red cat
    Dec 2013
    bayshore,n.y. USA
    19
    Kazuma red cat
    Hello and happy thanksgiving to all.
    I am looking at a 2006 110 cc kazuma red cat that needs a clutch and a battery for 200.00,
    does any one have any information on this make, or parts availability.
    I can fix it if I can find the parts.
    GOBBLE-GOBBLE
    Oswego NY
    1,935
    I fixed up a mercat50 for my neice a few years back..
    here is the site I used .. http://www.kazumapartsonline.com/
    ive used them for other parts as well..
    good luck!
    New England Ride 4/13
    Jan 2014
    Massachusetts USA
    782
    They are pretty much the same as most of the other chinese quads. Parts are available and cheap, and I too have used the site that MIK posted above, with good results. The chassis are all pretty basic and wimpy, and the engines are clones of Hondas, but they are good for their intended purpose, IE: teaching kids to ride. I have 6 kids and 2 chinese quads, and the machines have served me well. Only complaint is they both like to clog the pilot jet over the winter, whether or not I use stabil or drain the carb. No biggie, takes 5 minutes to clean.
    1985 Tri-Z 250
    1985 ATC250R
    Dec 2013
    bayshore,n.y. USA
    19
    Thanks for the website
    Apr 2013
    snyder texas
    456
    just adding in some info for you like said before all the china quads are nearly all the same lots of sites with cheap part prices having worked on 7 different quads of my own and for friends i will warn you of a few consistent problem areas i have run into on all of these---wiring splices are side by side with maybe a 3/4" piece of black tape around it, safety switches tend to go out, check valve lash regularly and watch for cracks in frames but they generally run pretty well and as stated are good cheap learning quads down here i have picked them up for $20 to $50 not running and usually can get them fired up in around an hour a little more time to make it ridable good luck and let em enjoy it
    you know whats right therefore you know what is expected
    Dec 2013
    bayshore,n.y. USA
    19
    Thanks for the heads up on that , I just checked the ad on that machine and it's gone but thanks for the good and bad on that type.
    devore,ca
    1,054
    The good thing is that 110 will bolt right into an atc 70. I got a kazuma 110 for free and that's what I did with it. Now I have a 70 with electric start, lights and reverse.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Apr 2013
    snyder texas
    456
    Way to repurpose great job
