Results 1 to 7 of 7
Thread: Chinese carbs on ebay for atc70
    Apr 2003
    Bay Area CA.
    2,638
    Anyone purchase one before? What was your experience with it? I was looking at them for a while and noticed that some are not built the same. As in if you mount it, the petcock and hoses would run to the opposite side. These usually ran $20-$30
    I ended up finding one identical to oem for about $50
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    HarrisoN* is offline At The Back Of The Pack Arm chair racerFirst time rider
    Bay Area, CA.
    156
    theyre on a par with oem in terms of running and tuning just made with low grade pot metal.
    for $20 theyre great and if it lasts a few years then get another.
    the jets and screws do round out after a while because of the low quality metals used but I think oem jets fit
    also see your from the bay.
    Jan 2014
    La
    1,062
    these wincycles carbs are really good Ive put them on two of my bikes and I have no complaints they are bolt on adjust the idle and go. They take the stock jets and the jets are made in japan. http://www.ebay.com/itm/Honda-ATC-70...ea5d11&vxp=mtr. they are a little more expensive than the other aftermarket carbs but id say they are worth it.
    82300R is offline Got The Holeshot Arm chair racerJust too addicted
    Dec 2005
    cobbwebs in your mind
    1,058
    I GOT a couple for my 80 110's. Had to like use the stock caps an not quite a direct bolt on...But worked out o.k. Better than nothing...
    I got a roll a quarters an making change !
    clmeue37's Avatar
    clmeue37 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2012
    Millington, Michigan USA
    205
    I run one of those carbs on one of the 110's and the 200s. No problems yet after almost 3 years.
    1980 Honda atc110, 1981 Honda atc110, 1983 Honda atc200e Big Red, 1984 Honda atc200es Big Red, 1984 Honda trx200, 1985 Honda atc200s
    Trikefest '15 '16
    Before destruction a man's heart is haughty, but humility comes before honor.
    -Proverbs 18:12
    Oct 2011
    Glamy's place
    99
    I have only heard good things about the chinese carbs for these small engines but I do have a stock atc70 carb if you are interested.
    Aug 2007
    Montana
    857
    I buy from ZOOM and have not had any trouble with the carbs! most I use are from Japan !!!! good stuff (7 so far)
    DO the Best With What you got !
    My Feed back :cool
