Results 1 to 15 of 20
Thread: Yamaha 225 choke/starting issue
    Nov 2014
    Zimmtown
    22
    I just got my very first trike (84 yamaha 225) it was kind of a basket case missing many things. One main thing I'm having a problem with is the choke cable. I'm missing the whole thing no plunger on carb either. Anyone have a idea on where I could get these parts and a little info on how to install onto carb. Also the electric start will just turn the motor over and not start it but I can pull the rope once and it will fire, does this have to do with the choke or some other problem?
    Mexico
    9,020
    If the choke assembly is missing from the carb and is open to air don't try to start it till you get it fixed. If you must start it for just a moment, soak a piece of rag in oil and stuff it into the hole to plug it.
    It sucks to get old
    Nov 2014
    Zimmtown
    22
    The choke plunger / spring is missing it is currently capped off and when I unscrew it, it looks like something is down in the hole I've heard of the choke getting stuck but this has no spring attached to it.
    glendive, montana
    1,822
    sounds like the plunger is still in there and the previous owner broke the cable off trying to get it out. take a picture of it. Also the cable can be found on e-bay, it is called a starter cable, yes I know has nothing to do with the starter but that is what it is called. I would have to look at one of my housings to double check if there is a way to force the plunger out without the cable attached. I think there is but not certain at the moment, it's been awhile since I've had to clean my carbs.
    Aug 2014
    South Louisiana
    1,915
    As for the e-start, my 200 did the same thing. I replaced the starter but you can rebuild it. I got a cheap starter and solenoid for $60 delivered and it works fine. Make sure you have the proper battery as well.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Nov 2014
    Zimmtown
    22
    The starter seems to work fine it cranks over and over the motor just won't start, is that the same issue you had?
    Nov 2014
    Zimmtown
    22
    Thanks for the advice know any way to get the plunger out. I will take a picture when I have time.
    Aug 2014
    South Louisiana
    1,915
    Yes it would turn the motor just not fast enough to actually start it. New starter same battery fired right up. It was just weak I guess. What do you mean by plunger?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Oct 2014
    Needle nose pliers. Spray penetrant around it. Heat from a heat gun may help. Mine was stuck but penetrant freed it up and I was able to get it loose.
    Aug 2014
    South Louisiana
    1,915
    Oh the choke... Short term memory loss is killing me. Yes do all of the above but add a shop rag, a vise, and a small set of vise grips. Also shooting with compressed air can blow it out of there if you can get to the other end of the orface.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    glendive, montana
    1,822
    going to add a pic for you of the only area able to be picked at other than the entry to the plunger, lost of penetrating oil and a small but strong screwdriver or pick and you should be able to get it out. There are 4 pathways leading to the plunger, if you need I will take a picture of them all for you, but pulling the carb and opening it up you should be able to trace them all your self fairly easy.
    Feb 2013
    Brazil, Indiana
    728
    To get the plunger out I would completely strip the carb and use a bit of heat on the body of the carb where the plunger is some penetrating oil to loosen the plunger up. Then use a pair of needle nose pliers and a small tip straight screwdriver to twist and pull plunger out. It takes a bit of time especially if the piece is really stuck in there. Ive done 2 dx carbs like that. Just dont scratch the walls when you are trying to get the plunger out. All of the parts you for the plunger you can buy and for a carburetor rebuild kit just use one for a yamaha 250 timberwolf, just use your old jets because the timberwolf ones are different . And if you need a choke cable use the one from the timberwolf as I believe the dx cable is discontinued.
    This is a timberwolf carb I rebuilt for my dx. They are basically the same other than the jet sizes
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
    Nov 2014
    Zimmtown
    22
    So back to my main question I would like some more suggestions about the electric start, I know moody said it was the starter but any other ideas it sure sounds like the thing is turning over very strong.
    glendive, montana
    1,822
    check your spark with the electric, sometimes it is a bad connection, other times it is a bad spot on the stator and flywheel
    Feb 2016
    Regina, saskatchewan
    21
    Hey so if someone could shed some light on my problem here...so my tri moto 125 will start and idle fine (without the choke even being threaded into the carb) but the second I go to thread the choke in my trike dies out ?!? Can anyone help with this I cannot figure it out
