Results 1 to 1 of 1
Thread: Correct Carb for 82 ATC70
    3wheeledjunkie is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Maysville, Kentucky, United States
    247
    Long story short I got impatient looking for a carburetor on ebay and ordered one without measuring the intake. Needless to say I got the wider model with larger slide as well. So, where is a good place to source a correct carb for this model. Rather have new and not spend a fortune on it, not looking for nos just something that will bolt on without me having to fiddle with the cable or drill out the mount to make it work. Found several smaller ones, but the choke and fuel valve are always on the wrong side, choke isn't a big issue but the fuel valve is.
    If it helps I purchased a 19mm, 1 7/8 hole center to center model. I'm assuming I need the smaller 17mm?
    1985 ATC250ES Big Red, Low Hours,
    1983 ATC185 200S jug, need crankcase or for sell
    1985 ATC110 Stock, Hondaline headlight guard
    1982 ATC70 Fun
    IT'S A HONDA
