Results 16 to 30 of 69
Thread: 4130 Chromoly Frame ATC250R
    Mexico
    9,018
    yeah I thought it was dirt cheap also - I've got to admit, looking at it, there is A LOT of time saving and easier ways to do things from the OEM frame that hes done here (which isn't a bad thing!) That helps contribute to that I'm sure, but I sure has heck wouldn't try to build one for $700. Not even $1400...
    I know a guy with modified 250R engine that would look great in that frame.
    It sucks to get old
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    That would be pretty neato
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    I wonder if there's enough room for a 450 motor. I'm going to reach out to him to find out. I would do that..
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Oct 2006
    2,504
    More pics from trx250r.net
    There was also a discussion which stated "he said that he could weld the rear linkage mount in so that if the buyer wanted, they could use the entire TRX450R linkage set up from swingarm to shock to frame."
    I tried on Mrs. Cleans faceplant account to find more information with no luck.
    That mock up tank needs to be polished.
    Oct 2006
    2,504
    Hard to believe it can sell for only $700. A good drag bike swing-arm (solid mounted on struts, no bearings) sells for more than that today: http://www.pmfronline.com/chassis_components2.php I would have figured at least 2 large for that frame.
    Search for Dave Moore racing. His swingarms range from 350-450 according to the site made of 1.5 inch 4130 chromoly.
    Very reasonable price with bearings installed in my opinion.
    Snohomish, Wa
    1,028
    You cant go wrong at 700 bucks. HRE was building 250r frames for $2,200. Not saying HRE is too expensive but it just shows the price difference on what we are use to. Even if people here are saying the frame needs to be finish welded, then people buying this frame with doubts just plan on completing the welds. Here it is people, finally a affordable chromoly 250r frame. Unless the people that get them start experiencing workmanship issues on the frame, lets support him. I am looking into his swingarms. great prices.
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Jul 2012
    Joplin, MO
    597
    Honestly if you look at the frame there really isn't a lot to it. And what I mean is he made the jig and he said he has the tubing laser cut so that takes a lot of labor out. $700 is an amazing price. I would gladly pay $1200 for one. He spent a lot of time in devlopement, which is worth a lot. It sounds like he is doing for love of the R and not for money.
    The Open Road
    4,736
    $700 is a STEAL!!! Period.
    I`ve built a couple bike frames from scratch plus worked @ RC Components where we built frames for custom builds (ours msrp`ed for 2800 and up). There is a lot of work that goes into frame building and you can scrap one merely by welding it in the wrong order. I saw quite a few frames built by new guys who think frame jigs are capable of keeping welds from pulling and therefore they would tig one whole side at a time. Once you pulled it out of the frame table, it would "spring" and the neck would no longer run parallel or the hardtail would have one leg run higher than the other side, etc. Frames look deceptively easy but truth is he`s got a lot of R&D, trial and error, and forethought to make a frame that nice.
    The Open Road
    4,736
    Quote Originally Posted by 83ATC185 View Post
    I would really like to see that frame neck welded completely. Other than that it looks awesome!
    I`m sure it is.....underneath that gusset.....no need for the neck gusset to get a full weld if you have welded the neck tube to the backbone and downtube both already
    Mar 2007
    Texas
    5,045
    I ain't knocking his workmanship. he did a nice job on it and it is a nice piece. I agree. if someone wants to be certain they can get it finish welded for cheap probably $100 or less if it makes them feel better. other than that, I say thumb's up!
    ________________
    https://www.mikesatvfix.com
    Mexico
    9,018
    Quote Originally Posted by oscarmayer View Post
    Solid weld is not always better than stitches and the man who built that is an artist, not some hack who doesn't know how to finish his welds.
    If you take that frame and add weld to it improperly it will twist and bend. Such is the relationship between steel and heat. Then you'll need to look around for someone with a torch, bucket of water and a rag to get it straight again and you'd better hope they know what their doing.
    I hope someone here buys one.
    It sucks to get old
    Oct 2014
    NEBRASKA,USA
    106
    that is a nice frame
    Live Oak, FL
    15,069
    Yeah, I'm lead to believe that it was very meticulously welded that way so as to prevent war-page. Sometimes people look at factory frames and see tabs and gussets and think they should be finish welded, but they are intentionally done that way. Aaand...sometimes they aren't too But this thing is so carefully crafted everywhere else - it has its reasons I'm sure.
    Mexico
    9,018
    On that note... For a few years I was tasked with putting together welded suspension components for MCI prototypes. Basically they would give you detailed drawings and you would build the parts by hand all the while thinking of ways to tool up for the real deal and do the work in the most efficient way. Then there would be regular meetings in which you would get face time with the engineers that you use to ask for changes to better accommodate production, or lower costs. It was like being in a room full of Barnetts.
    Once you had a few prototypes complete they would put them on what they called a "Shaker" (never got to see it). I believe it was a hydraulic powered fixture that could simulate road miles. Each prototype would spend a week or so on the Shaker and then if needed we'd get a revised set of drawings and start again.
    Anyway, my point was that by the time we'd get designs approved it seemed that anything over 1/2" thick was always solid welded and anything 3/16" and under was always stitched 1/4" and 3/8" materials could go either way depending on the stress points they covered.
    At the end of the day and for the purpose of the frame in question here, if a crack begins in a solid weld it will eventually crack the entire length. If a single stitch cracks the crack stops when it runs out. It's the same principal as drilling a hole in a crack, except you are building the hole into the design. It also allows a minuet amount of flex to the largest component in the assembly without the risk of cracking shorter parts attached to it.
    It sucks to get old
  15. #30
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    You never hear anybody speak of shot peen. I worked in a shop where we did shot peen on aircraft parts. That would be a great investment to a freshly built raw frame. It releaves any stress in the steel from welding, reduces cracks drastically and is affordable.
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
