Results 1 to 15 of 19
Thread: 1985 Kawasaki Bayou 185 struggling to run.
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    I have an '85 KLF185 and it will start and it will idle with choke on and eventually fully open once warmed up. But when I give it gas to go it struggles bad and kind of jumps and is jerky. It's not smoking at all. I have a pinky sized hole in the exhaust, but it's been there. I have noticed that my fuel pump is clicking a lot more than it used to.
    Someone said maybe it was my ignition coil, but I would think it wouldn't idle or stay running that long if that was the case. I mean it has to be getting some gas or it wouldn't run at all.
    Any thoughts?
    1985 200S - fixer upper
    Jan 2011
    Greene,Ia
    688
    me personally, id get that hole in the exhaust fixed.
    and being as you say it runs with the choke on, but takes some finess to keep it running with choke off, i would clean the carb.
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Yeah it will eventually idle fine once it is warmed up, was that way when I got it. I don't have much luck with those carbs once I pull them apart and start cleaning and stuff. My fuel pump would always click, but it would slowly stop once under pressure I guess. But lately it's constantly clicking pretty fast, like this: 200 BPM
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    If I have another exhaust leak other than the one in the tail pipe, like where the header meets the head, will that make it run "jerky" like that? I'm going to post a vid.
    Jan 2011
    Greene,Ia
    688
    a dirty carb will cause it to be jerky, and inconsistent. start there
    1985 Honda ATC 70
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    http://www.sportsmanstuff.com/VIDEO0006.3gp
    You can't really hear the struggling that good once I start backing it up, but you can hear the clicking at the end after it dies.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    K I'll do that.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    So I cleaned the carb and it's still doing the same thing. It was dirty as all get out for sure. It's smoking white smoke real bad. But maybe it's flooding or something? It's not black smoke. Not sure what it could be.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I rode it around and it seemed to clear up a bit. I think now it's the hole in the muffler that is making it sputter now. Going to replace the copper gasket by the manifold and get that hole patched up. I have an oil level looking glass on the side of the motor. The oil is in range when the engine is cold, is it normal for there to be no oil visible in the looking glass when it's running?
    Jan 2011
    Greene,Ia
    688
    where exactly is this hole in the exhaust?
    as far as oil, yes it will be difficult to read via the sight glass while running as the oil is being circulated through the motor.
    not sure what white smoke would be on a air cooled machine. possible the headgasket might be messed up?
    1985 Honda ATC 70
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    It may just be because it's cold (the motor and outside). Once I got it warmed up (drove it around lightly for ~10 min.) it wasn't smoking at all and didn't smell funny. The hole is in the muffler, on the underside, probably 5 inches or so from the real muffler hole.
    I lost my friggin' screws that hold the airbox lid down.... After jimmying with the carb and air filter it seems to be doing good. Now all I have is the lame jerky back pressure from the muffler now.
    I think it may have another leak somewhere further up the muffler/exhaust head because when first starting it up, it will smoke towards the front of the bike. Probably going to take it off so I can inspect it better.
    Thanks for the help.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Also, when I was removing the carburetor, I noticed that the boot that goes from the airbox to the carb was completely loose. I've never checked before so maybe it shook lose since I bought it and made it start acting up by letting in too much air? Not sure. Going to get the muffler stuff in check and will post results.
    Thanks again!
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Okay, so got home cranked it up and it's doing the same thing. I guess it's down the the fuel pump and ignition coil...
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Okay, so I've:
    1. Cleaned the carb.
    2. Checked the air filter.
    3. Put the carb back on (fastened down the intake boot good too).
    4. has spark.
    5. fuel pump is shooting out gas.
    It's still jumping and jerking and I don't think the exhaust has anything to do with that.
    I'm at a loss.
    Jan 2014
    La
    1,062
    Your top end might need to be rebuilt. the white smoke untill the engine warms up is a sighn that you need new rings.
