Results 1 to 10 of 10
Thread: 250r axle question
    Winnipeg
    211
    250r axle question
    Need an axle for a 1985 250R.. will an 82 250r axle fit?
    Jul 2014
    Lloydminster, Alberta
    503
    http://www.ebay.com/itm/Honda-250R-2...6b75a5&vxp=mtr
    this ones on ebay for fairly cheap
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Jul 2012
    Joplin, MO
    597
    You can use an 86 axle or trx axle as well. The only difference is the sprocket. 82 will not fit.
    Sep 2011
    Ocean Beach, CA
    1,333
    Noooo. With all due respect Steveman, you are misinformed.
    for OEM axles:
    you can only use an 85 axle with an 85 carrier. thats it.
    86 and TRX stuff will interchange, but not with 85 carrier or axle
    Jul 2012
    Joplin, MO
    597
    The carrier is different but the axle is the same size.
    Jul 2012
    Joplin, MO
    597
    An 85 axle wont work in an 86 up carrier because of the sprocket hub
    Sep 2011
    Ocean Beach, CA
    1,333
    thats what i meant. the sprocket hubs on OEM axles are not removeable and therefore the 85 axle and sprocket hub will not work in anything other than an 85 carrier
    aftermarket axles with removeable sprocket hubs can interchange between all years and carriers, provided you have the proper sprocket hub to match the carrier.
    Las Vegas, NV.
    2,487
    I hope this explanation clears this up for you guys:
    You cannot use an '85 axle in an '86-89 carrier because the sprocket hub will hit the carrier.
    But, you can use an '86-89 axle in the '85 carrier as long as you use the '86-89 style sprocket and mounting bolts.
    Blossvale NY
    4,563
    Correct!
    I am using 86-89 axles in both of my 85's. Just have to run the 86-on rear sprocket. I have no issues.
    Don't know about running an 82 axle in an 85 though... I wouldn't think it would work.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Sep 2011
    Ocean Beach, CA
    1,333
    i suppose i am misinformed. a buddy unknowingly put an 85 axle in an 86 carrier and it threw the chain into his case and ended his race season ... on a test ride
