Results 1 to 9 of 9
Thread: ATC70 rear suspension
    Dec 2002
    Central Pa
    73
    Anyone out there know of any aftermarket frames? I'm going to be swapping out my old frame on my XR50 with a chromoly one, and going with a different swingarm. So I'll have a single shock frame and swingarm to start with. My only hang-up is how to set up the chain adjusters. Brakes may give me some headaches also. Anyone have any ideas? The rear housing is welded directly to the frame on a 70 and I dont want to cut the original frame up, so I'll probably build my own unless there may be something out of a 90 or 110 that might work. Wouldn't really care if I had to use the axle and other components. Wider axle would be a plus anyway.
    83' ATC70
    85' ATC70
    83' ATC200x
    96' TRX90
    05' CRF50- The only thing left that hasn't been modded out are the engine cases.
    Clarks Summit PA
    1,236
    well i can tell ya... if you want to play with atc 70 frames... go ahead.. they are still a dime a dozen... you can usually get a frame for like 30-50, plus shipping.. so give it a try.. you will not find a rear suspension for an atc 70.. unless you live in cal.. and then you will only increase your chances.. i can tell ya for front suspension.. use an ct 70 front end with a honda cub tire..
    Ride it like you stole it! And never look back! They are too far behind to see!
    Dec 2002
    Central Pa
    73
    Already did that brother. Thanks for the post.
    83' ATC70
    85' ATC70
    83' ATC200x
    96' TRX90
    Feb 2003
    You guys sound very knowledgable in ATC70 scene.
    I have a 84 atc70, that I use as a pit bike, that I would like to start modifying.
    What tires are you running on the 8x8 wheels, and who sells the wheels? I have looked and it seems to be a tough task.
    CT70 front end, what years?? How easy is it to adapt it to fit the atc?
    Any other cool mods that I should look into??? I like the crazy looks I get when people see a big guy riding a atc70, it will only get better with a tricked out one.
    Thanks,
    fourwhls
    newcastle australia
    38
    gday mate
    build a new swingarm and build it so it uses a rear axle hub off a atc90 better bearings wider axle use the same hubs off the 70 use ct 70 front forks, the 1 peice rear 70 fender and dont use the 70 motor use the atc 110 as u can bore and stroke them out to about 180 i think 1 of my mates built 1 like this smokes 200xs easy handles brilliant 2 also a rear axle hub fits in a 70 frame u just drill out the 70 hub and drill and bolt the 90 1 in ive just done it on my 70
    "LOVIN THE FEELIN OF 3 WHEELIN"
    1986 250R
    1986 350X
    1984 250R
    1983 200X
    1983 ATC 70 110cc engine
    1983 ATC 70 200X replica engine barrell layed down electric start (not finished yet).
    "AND ONE MEGA TRAILER TO CART EM ALL ON!!''
    Dec 2002
    191
    though I can't quite understand the previous statement, I did see that he said to use a 110 motor... I would say NO, stick with the 70, or build a tricked out 110. Powroll has a 120 kit for the little 70 and I have read good reviews about it. check out www.powroll.com they can give yu more info. Also I don't see how this will be possible without cutting on the 70s frame at all. You need to cut the rear end out and adapt a swinger to it (i would go with 83-85 200x). and then weld in shock mounts. Best of luck to you.
    Josh
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    how about yz 80 front forks?? lt 500 front tire,,,,
    KASEY's Avatar
    4,244
    no link rear suspension 200x rear shock with a 250r spring,,,,
    Ithaca, NY
    2,596
    that rocks! cant wait to get my yamaha 175 rear suspension installed!
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
