Thread: 86 Tecate swingarm spacer measurements needed
    Enumclaw WA
    89
    When I took my 86 Tecate apart it was missing both the inner spacer/caps that go between the swingarm and engine. I was hoping someone had one laying around that they could measure for me so I can make a set. I have a lathe and material already but just need to have something to go off from. Thanks
    Nov 2006
    southern oregon
    2,338
    I don't have an 86, but if it comes to it you should be able to measure the difference between the cases and swingarm and divide by half. Make it fit snug so the swingarm doesn't "squeeze " more than it needs to.
    2-stroke lover
    Sep 2005
    MICHIGAN
    2,027
    i will try to remember to bring some calipers home and measure them over the weekend.
    You should be able to reverse engineer them.
    Small ID is axle size.
    Small OD is swinger hole size.
    Large OD is swinger OD size.
    The OAL and the boss height is the trickier part.
    86 T3
    84 T3
    86 KX250
    Enumclaw WA
    89
    Yeah like you said nd4speed the oal and boss height is the main thing I was worried about. Thanks
    Sep 2005
    MICHIGAN
    2,027
    Has more features than I thought it would.
    OD chamfer about .060"
    id chamfers .040" (both sides)
    seal groove about .030" wide depth sorta measured in last picture
    seal groove starts about .030 from the face.
    Those are just rough guesses without having something like an optical comparator to measure it accurately.
    Attached Thumbnails Attached Thumbnails P1030481.jpg   P1030482.jpg   P1030483.JPG   P1030484.JPG   P1030485.JPG   P1030486.JPG
    86 T3
    84 T3
    86 KX250
    Enumclaw WA
    89
    Thanks nd4speed, I had no idea there was that much going on either. From the very limited pictures I had seen I couldn't see most of that. I will have to try and get out to the lathe this weekend and try to get some made up now. Thanks again
