Results 1 to 15 of 15
Thread: honda 90 flat tracker
    R.J.M.'s Avatar
    R.J.M. is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Missouri
    181
    I traded some atc 70 stuff last week for this little trike, kind of an ugly little trike but I think it's neat. I'm wanting to install a 70 wheel and hub on the front. will the 70 front hub fit the 90 axle or are they different size? Im not sure if the front axle that's in it now is the factory one or not. Any advise on how to go about the 70 front tire and wheel will be greatly appreciated.
ID:	206124Click image for larger version.
    1986 250R
    1985 Tri-Z
    1986 200X (wife's)
    Honda 70's-x4 (kids)
    1982 250R project
    Mar 2013
    Central PA
    2,362
    Those kart tires make that rear fender look cool. I bet that'll look neat when it's all done up.
    R.J.M.'s Avatar
    Jul 2013
    Missouri
    181
    Thanks ghost I really like the way the fenders look also. Need to do some research and see what all you can do to these motors and what's available aftermarket wise. Would like to make it a nasty little flat track bike just for the hell of it lol. Anyone have any suggestions on the front axle to be able to run the 70 hub and wheel?
    1986 250R
    1985 Tri-Z
    1986 200X (wife's)
    1982 250R project
    HarrisoN* is offline At The Back Of The Pack Arm chair racerFirst time rider
    Bay Area, CA.
    156
    cross reference the wheel bearing part numbers and sizes on partzilla. worst case you need a custom axle.
    R.J.M.'s Avatar
    Jul 2013
    Missouri
    181
    [QUOTE=HarrisoN*;1344797]cross reference the wheel bearing part numbers and sizes on partzilla. worst case you need a custom axle.[/QUOTE
    Never herd of partzilla I'll check it out right now, thanks for the help
    1986 250R
    1985 Tri-Z
    1986 200X (wife's)
    1982 250R project
    Jun 2013
    Oceanside, CA.
    612
    RJM, can't tell in your first pic what type hub was used to mount the original go kart flat track tire/wheel assembly, but if your going to use the ATC70 wheel assembly they are 3 on 100 bolt pattern. You should be able to use a ATC90/110 '85 thru '80 axle and tube spacers assembled with your hub and would install onto your forks no other mods needed.
    "HJ"
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    R.J.M.'s Avatar
    Jul 2013
    Missouri
    181
    Quote Originally Posted by HairyJR View Post
    "HJ"
    Hey thanks HJ! That's what I was looking for. The axle that is in the go cart setup is just barely to big. I thought if nothing else I would find a machine shop and have them mill it down so it fit. Thanks again!! Now I'll look for a 90 axle setup
    1986 250R
    1985 Tri-Z
    1986 200X (wife's)
    1982 250R project
    Mar 2013
    Baldwin, Wi
    603
    Quote Originally Posted by R.J.M. View Post
    Contact member shortline on here he has all the hot hod parts you could want.
    85 Tri-z Basket Case
    Mar 2011
    Grafton, Ohio
    91
    Are those 90 rear hubs bolted to the kart wheels in the back, or some other kind of setup? More pics please
    The Open Road
    4,736
    ^^^ I agree with this guy^^^^
    I`m dying to see more detailed pics of that whole setup...with closeups galore
    Please and thank you
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    I too want to see the hubs. Being it has Us90 foot pegs and fenders.. Could it also have the US90
    Axle and the hubs for the one piece wheels. I don't know the bolt pattern. But, I'd guess some kart wheels
    Might fit.
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Aug 2012
    richmond nh
    647
    If you use the 90 spacers and the 70 hub on a 90 front end it is bolt on. I did it on my 1979 90 and it worked fine. Also the axle splines are the same.
    R.J.M.'s Avatar
    Jul 2013
    Missouri
    181
    ok so here's pics of the front setup......
ID:	206290Click image for larger version.
ID:	206291Click image for larger version.
ID:	206292Click image for larger version.
ID:	206293Click image for larger version.
    And here's pics of the rear......
ID:	206295Click image for larger version.
ID:	206296Click image for larger version.
    1986 250R
    1985 Tri-Z
    1986 200X (wife's)
    1982 250R project
    Jun 2013
    Oceanside, CA.
    612
    One thing is for certain your rear axle assembly is from a early era '70 US90 thru '74 ATC90 6 spline axle and hubs. Those early axles where smaller in diameter and would bend easily, need to keep right side axle/hub nut tight tend to work loose when riding. Rear fender looks to be '73 and front fender '74 Daytona Orange plastic fender.
    Any luck finding a front axle?
    "HJ"
    ’84 YT60
    ’90 LT500 Quadzilla
    Mar 2011
    Grafton, Ohio
    91
    If you wanted to, you could put the atc70 front end on it to lower the front down some. Then you could the run all the stock atc70 front end bits and it'll level out the stance some.
    Last edited by 200X FT; 12-23-2014 at 02:07 PM. Reason: clarify. atc70. not 70, as in the year
