honda atc 110 cdi conversion
i have a 1980 atc 110...i want info about cdi conversion...it is possible? I think so but need more info about this conversion.like if i juste have to swap the electrical and cdi component...if it will work whit the magneto or other component in the engine base...dont know enouf mechanical to open the base....thank
I found the info on other treads...not a good idea...crankshaft not same and points are 6 volt and cdi 12 volt.
a cdi conversion gets rid of the points, so itll all be 12 volt
2006 Yamaha Raptor 700
2004 Kawasaki KFX700 V Force
1985 Suzuki LT230GE(wifes toy)
1985 Honda ATC 70
1979 Honda ATC 70 (daughters toy)
Sorry don t undersands...rids??...english is my second language
Its more easy to find a complete cdi motor...than made the conversion
gets rid of = you remove from. meaning you will remove the factory points from the engine, to install the cdi parts.
1985 Honda ATC 70
//ArrowChat Integreation Code
