Thread: 85/86 250R axle clip collar
    Jul 2014
    Lloydminster, Alberta
    503
    Since these seem hard to find does anyone have a solution if you don't have this collar? Or does anyone have one theyd give up, gathering some parts for a project. Number 15 in this blow up http://www.servicehonda.com/parts/lo...HA2FHA28F1300A (wouldnt let me upload pic)
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    na
    5,702
    I had a 250x years ago that i had that issue with. I made a spacer on the back side of the threaded collar about 3/16 thick to bring the nut out far enough to hit the snap ring and then some, then I dremmeled a bevel on the inside edge of the outer nut to slide over and catch or retain the snap ring and go over it then tightened it down like normal. This was back when you had to wait 2 weeks to get stuff from a dealer. It wont work unless you space the rotor side of the threaded sleeve. I had to ride that weekend, it held up great and I forgot all about it 2 years later until I took it apart for bearing replacement in which then I had the parts I ordered a few years prior.
    Proudly NOT a member of
    "Team on the Teat"
    Jul 2014
    503
    Thanks Mosh!
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Jun 2009
    Leander TX
    2,217
    As I vaguely recall I think I have a 400EX nut on my 350X - the nut and collar are one piece.
    poohbee1's Avatar
    poohbee1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    terre haute indiana
    404
    The new Honda part is the collar built into the nut #14 doing away with the collar your talking about altogether. If you are doing a perfect resto its going to be hard to find that collar in good shape .
    Jul 2014
    503
    so what you're saying poohbee is if I order that nut from honda it'll have that incorporated into the nut? And it's just for a project I have toying around in my head, have an extra 85R axle just no hardware
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Oct 2006
    2,504
    I think I have a few of those laying around matter of fact I have a complete working OEM fade nut assembly up for auction on a well known website. PM me and we can work something out if you want.
