I have a 77 ATC 90, for some reason the engine doesn't want to get gas from the carb. The 3 wheeler will fire right up if I pour some gas into the intake, but it won't run from the gas tank. The pilot jet and main jet are spotless, the carb is all very clean, the float height was just set, and the needle is not sticking. It doesn't seem like the spark plug is wet, so I'm thinking it has to be something within the carb that I just can't see. My buddy has an ATC 70, would that carb fit? I could borrow his and switch it out. Any ideas?
Not sure if this matters but the altitude changing knob thing is stuck as well and wont move
